1997 Sidekick, 1.6L, SOHC, 16V, MFI - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1997 Sidekick, 1.6L, SOHC, 16V, MFI (/thread-1997-sidekick-1-6l-sohc-16v-mfi) |
1997 Sidekick, 1.6L, SOHC, 16V, MFI - gcates - 05-08-2023 Hello All, I purchased a Sidekick with half an engine and am at the point where I am trying to figure which vacuum lines go where and what parts are missing. Todays challenge is finding the vacuum port on the intake for the transmission vacuum modulator. The evap cannister is missing from the vehicle as well. Any assistance would be greatly appreciated. Thank you, Grover RE: 1997 Sidekick, 1.6L, SOHC, 16V, MFI - fixkick - 07-14-2023 (05-08-2023, 09:29 AM)gcates Wrote: Hello All, easy stuff that year is? 2door or 4doors? what engine is there 8valve or 16valve (both are 1.6L) G16./ what transmission is ok must 3speed as only it has that. the rear of the THM180 box has vac modulator hole empty? the canister on most are 2hoses. one to tank vent and one to VSV EVAP valve on intake man. the intake manifold for 4speed has no MOD Vacuum port at all seen here and why see A/t MOD ports here on rear of intake manifold. https://fixkick.com/engine/8v/vacuum%20ports/html/image_2.html and mod vaLve at end of 3L30 http://fixkick.com/tranny/slush/slide3L30/html/image_6.html the purple code i think is correct (color means how heavy is the car) vacuum load sensing. http://fixkick.com/tranny/slush/slide3L30/html/image_14.html |
