1996 Sidekick JLX Sport 1.8l Auto Transmission replacement with 1.6l? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1996 Sidekick JLX Sport 1.8l Auto Transmission replacement with 1.6l? (/thread-1996-sidekick-jlx-sport-1-8l-auto-transmission-replacement-with-1-6l) |
1996 Sidekick JLX Sport 1.8l Auto Transmission replacement with 1.6l? - ARMONKEYBOY - 04-27-2023 Brand new here and happy to have found / joined. I have a 1996 sidekick JLX Sport 1.8l and need to replace the auto trans. I can't find a 1.8l and I have seen that the 1.6l will work, but you have to use 1.8i bell housing. Is this true? I sincerely hope that it is as I have put approximately $7k into this little monkey, and I need it to finally take me down the road. Can anyone help me with this little problem? I would be forever grateful. Thank you in advance!
RE: 1996 Sidekick JLX Sport 1.8l Auto Transmission replacement with 1.6l? - fixkick - 07-14-2023 just get a real rebuilder shop do the rebuild the G16B box is 03-72LE GM/GEO RPO code M41: LE= E for Electronic. the base transmission is used on all these cars. A44DE made by Japan AISIN company/ http://www.shinseiauto.com/japanese/transtar/Toyota.pdf using other boxes can be hard to do the TCM must like he box and for sure the gear ratio's, besides just fitting. or ratios for G16 is Ratio’s: 1=2.83:1, 2=1.49:1, 3=1.0:1, D=0.73:1 and R=2.7:1 http://fixkick.com/slush-pump#4speed_fast any shop that does toyota transmissions will not fear any A44DE . and MAZDA, my wife has one in her Mazda MX5.1999 odds and ends this box. http://fixkick.com/tranny/slush/slide-03-72LE/html/index.html are you sure its bad? and not just rusted up and jammed up kickdown cable.? tcm errors on speed sensors or solenoids shifters? does manual mode fail./ as stated here, this is so cool on this car. this test http://fixkick.com/tranny/slush/slide-03-72LE/html/image_24.html RE: 1996 Sidekick JLX Sport 1.8l Auto Transmission replacement with 1.6l? - fixkick - 07-14-2023 truly sorry I am so slow,and replys , are not email sent now. I have been busy on house. new roof ,new HVAC,and new tankless hot water and now R40 Insulation, I am tired. tranny swaps are not easy on any car, (automatics) tell me what it does wrong do the manual mode. yet? |
