1992 Suzuki sidekick transmission swap - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1992 Suzuki sidekick transmission swap (/thread-1992-suzuki-sidekick-transmission-swap) |
1992 Suzuki sidekick transmission swap - RFWD - 11-14-2022 Hi There. I have a 1991 Suzuki sidekick with 4 wheel drive automatic transmission which I swapped out for a 1995 5- speed manual transmission. Now it's time to do some wiring on it. On the 1995 5- speed there are three sending units on it. Two in the front driver side are up close too the top. The wire colors on the front one is Yellow/ red dot and Red/ Blue dot. The second one beside it has two wires one Black / Green stripe the second is Blue / Red dot. the rear sending unit has two wires one Orange/ Black strip the second Black/Green strip. I believe the rear sending unit is the back up switch. Can I have help on the other three sending units. Plus what wires do I use from the automatic transmission wiring harness to attach them too. Thanks
RE: 1992 Suzuki sidekick transmission swap - fixkick - 12-14-2022 my guess is only reverse needs be connected for reverse lamps. we have 91 schematics on the main page the other switch is 5gear can block some ECU things in 4wd, (i forgot what but the 1996 free manual covers that) 5SP/ page 14 backup #1 http://fixkick.com/tranny/sidekick_drivetrain_manual.pdf 91 is 8v engine and my schematics pages have full info there. 21 oages does it all. page 10 shows lamp backup. and page 17, the lamp is already grounded so back switch ,RED just switches power 12v to rear lamps. back. http://fixkick.com/look/91-complete.pdf |
