Wiring Help! - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Wiring Help! (/thread-wiring-help) |
Wiring Help! - sina27 - 10-13-2021 Hey guys Recently got myself a 1992 geo tracker, 4WD, 2 door, 8 valve TBI. NO AC. There are quite a bit of modifications I am addressing. The previous owner connected an alarm system under the drivers dash via the ECU wiring. Seems that the main ignition wire (black and red) has been wired through the alarm system, as well as a black wire (assuming this is ground). Im going to remove the alarm system. When I looked under the drivers side dash, I noticed some ports and connecters that dont have anything plugged in. I wanted to make sure that this is normal? And if anything is missing? Can somoene take a look at these images and let me know? The first image shows a black connecter (12 pins) and a white connecter (not sure how many pins) right next to eachother. Should anything be plugged into these? The second image is part of the wiring harness under drivers side dash. There is an orange wire (with small blue marks on it) that isnt connected to anything. Does anyone know what this is for? Here are the images: https://imgur.com/a/WMtBs3F Thank you!! RE: Wiring Help! - fixkick - 10-13-2021 (10-13-2021, 03:44 AM)sina27 Wrote: Hey guysall these car have option missing new or now. 4door even more, (rear windows wiper/waster and electric windows, and cruise control missing, what transmission is here, 5speed stick 3spead or 4speed auto if came new with 4speed auto and some one changed it to 3speed, the TCM module is now missing. 2door , rag top car? (some are metal top in Canada. your photos. #2 is factory, 2 connectors, the yellow one is one is RWAL DLC, (Diagnostic connector , seen here https://fixkick.com/BrakeLamp.html and 2nd one is tranny DLC, seen here. https://fixkick.com/CEL/DLC/tcm-dlc.jpg the black one is the Alternate ECU DLC connector, same as one (different pins and plug) under hood , DLC net to battery photo 2 is a mess, Id remove all alarm and wires first going back to stock , then each wire (most have 2 colors, body and stripe) and each color we do know. full schematic on 95 is on my schematics page, same as 92.mostly the colors of the suzuki wires are key good luck |
