X90 window motors - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: X90 window motors (/thread-x90-window-motors) |
X90 window motors - maint - 07-30-2021 I had issues with my X90 passenger window not working and I thought I had it beat. The old channel rubber was hard to pull along the edge of the window even when out of the channel. I changed it to a flocked type. Moves a lot easier now. The R motor was dead when I got the car and I put in a Toyota motor to replace it. Toyota motor looks identical to Suzuki just need the Left one turned upside down to go on Suzuki Right side. It strained to lift the window and I spent a lot of time troubleshooting it. It also died and at that time I changed the motor and rubber out. The last few weeks I had to sometimes open and slam the door for the window to move. Once started, it will move under power until I leave it for a while. Getting worse so back to troubleshooting. Checks out electrically but motor gets hot and doesn't move the window. Is it possible I have a bad spot on the motor from bumping it to the physical stop ? Motor looks the same but may not be? Suzuki only sells motor and regulator (not a cable type in these) as a unit and they are $$$$ Any suggestions? RE: X90 window motors - maint - 08-01-2021 I think I solved it. (part2) Jumped right to the leads near the motor with no movement so pulled glass and regulator to check brushes. Turned out to be corrosion at the bushing for the rotor. Could barely turn the rotor by hand when only thing holding it was the bushing. Cleaned and lubed it and it spun easily. Bad news is I broke a brush reinstalling the rotor so bought a new Dorman one for a 97-01 Camry. I guess 20 year old parts, Toyota or not, aren't going to last forever. update: Dorman quality not up to par. They forgot to thread the holes to bolt it on to the regulator. Back to store to exchange for a Cardone rebuilt. Window works better now than it has since I got the car, 20 yr old used motors from the wreckers may not be the way to go. |
