93 Sidekick A/C Condenser - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 93 Sidekick A/C Condenser (/thread-93-sidekick-a-c-condenser) |
93 Sidekick A/C Condenser - Falconius - 06-23-2021 Hi guys! im attemping to figure out what i need to do to fix my A/C. my old condenser's connector popped off at the upper hose. so i looked around and picked up a condenser for my 2d 93 sidekick. well that one has different connectors for the hoses, and the lower condenser connector is on the other side of the condenser... its supposed to be the right part, but seems wrong. the old one was mounted at 4 points to the radiator, this one has 2 mounts to radiator, and 2 points where it would sit into a bracket... but i dont have that bracket. im relatively confused here. I cant seem to find upper and lower hoses that have the connections i need. It appears this had already had a conversion to r134a, as the Schrader valves for the manifold fit properly. i have a couple pictures here. any help would be appreciated. thanks! RE: 93 Sidekick A/C Condenser - fixkick - 06-23-2021 (06-23-2021, 09:18 AM)Falconius Wrote: Hi guys!28 years old, any thing there is possible (grin) EPA USA forced the change Vehicles made before 1994 use R12, or Freon®, then R134a and the changed to PAG oil and all new pressure rules. and huge tax for reUSED R12 '(it's not expensive it's all tax worse than booze or tOBACCO $$.) hi/low. spec PSI new hoses, new condensor, now compressor, evap, expansion valve and more lots more. brackets and such. the laws even mandated fittings changes so R12 shops done not get confused, and mix gases. R12 refrigerant is no longer available to the consumer because of environmental concerns, but is still available for use by trained technicians and installers. In fact, the main reason R12 is still available is these same technicians have continued to (recovery systems) recycle, clean, and reuse the remaining supply. New R12 is no longer being manufactured.(USA) i'm RUNNING r22 IN MY HOME NOW 15 YEARS. don't ask what it cost to add it. (a horror) good luck finding parts, it was an add on option new. ' see photo 95 here. https://fixkick.com/air-conditioning cheers to you see next post for more facts and P/n real RE: 93 Sidekick A/C Condenser - fixkick - 06-23-2021 [quote pid='13997' dateline='1624405077'] 93 AC (USA)? [/quote] i can tell you all partnumbers there. and the exact VIN number change over for those parts , seen in the master parts lists. ok i have the book open the answer is more complex and different parts 93/94 years and for sure 2door or 4door car the change happened 1994. as we know the the first 1994 cars are built in the factory starting July2, 1993(label vin 1994) there is on records on this date but if the VIN has code for 94 it is ,R134a. best it to buy parts for 1992 , first year of 16valve. is car 16v , is car 2door or 4door, the parts are not the same and VIN 94 it all changed. then they should fit. you got a new condensor? or used or rebuilt or? suzuki lists 5 condensors, 92-95. even not the same for AT and MT tranny after market shows 2 (R12/R134a) https://www.rockauto.com/en/catalog/suzuki,1993,sidekick,1.6l+l4,1271393,heat+&+air+conditioning,a/c+condenser,6708 the 2 engines then are not the same nor same engine radiator or its related parts, nor condensor.
