Smells like Gear Oil - sina27 - 04-13-2021
Hello
Have a 96 tracker 5 speed 2WD. The transmission was rebuilt 5 years ago. Last year I changed the clutch and put in some amsoil manual trans fluid gl4.
I noticed lately when I’ve been driving for a while with windows up that I smell the tranny fluid. While driving I pushed up the rubber gear shift cover and saw a little smoke and it smelled worse. Could the fluid be pushing up into the shifter box?
Can the fluid be over filled or under filled and give this symptom?
To be on the safe side I ordered two quarts of the oem GM tranny fluid which should arrive later this week.
Any advise would be appreciated
RE: Smells like Gear Oil - fixkick - 04-13-2021
(04-13-2021, 06:31 AM)sina27 Wrote: Hello
Any advise would be appreciated the right side of the box has fill hole, and is the level hole, fill only to bottom edge of side fill port. (10m inside square drive)
the top of the box has 2 rubber rail plugs that can fall out or leak. they are RTV glued in best.
there is no GL4 in the shifter box this is greased only . the shift rails would need to be a wreck to let GL4 to the upper shift gate box. blow the gate box yes. o
the top vents on the box must be free flowing (air vents) and do not block the 4wd breather to trans behind engine head must not be plugged up ,there a water baffle on top of that hose
and some find it vent baffle missing so cork it, this is a dead wrong act blocking any air vents. to 2 axles or to 5sp top of box. air vents.
if not overfilled I be the vent is blocked, it must breath air.
some nuts try to fill the box via the shift gate and fails, none hits tbox below, and it burns up drained.
this is the shift gate that is grease only.
![[Image: cheating1.jpg]](https://www.fixkick.com/tranny/cheating1.jpg)
all this is grease only no GL4 lube
part 20 is vent baffle must never cork like plug it is a vent.
GL4 lands only on parts ID 1 and 2 forks. and 3, 4, and 5 rails and ends there, plugs 13 both not missing and wants to leak, lacking RTV sealant.
![[Image: rails.JPG]](https://www.fixkick.com/tranny/rails.JPG)
good luck finding true cause, cheers and good day to you.
RE: Smells like Gear Oil - sina27 - 04-13-2021
Thanks for the reply Fix Kick.
I will check part 13 in the diagram and make sure they are glued in and not leaking. \
This car is a 2WD. Would my car still have the part 20 / 21 4WD breather / baffle? Is this the only vent, or are there a couple more I should be looking out for?
If part 20/21 isnt the only vent, is there a diagram of where the vent(s) should be? I can check to make sure the vents arent blocked once I get home.
Thanks for the advice!
(04-13-2021, 08:21 AM)fixkick Wrote: (04-13-2021, 06:31 AM)sina27 Wrote: Hello
(04-13-2021, 11:43 AM)sina27 Wrote: (04-13-2021, 08:21 AM)fixkick Wrote: (04-13-2021, 06:31 AM)sina27 Wrote: Hello
good luck finding true cause, cheers and good day to you. the 13 love to leak, and make the outside wet with GL4 and stinks bad. for sure if both top shift boots are cracked and fumes rise up to you.
hope it is just something simple found..
good luck.
