Low 5v ref - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Low 5v ref (/thread-low-5v-ref) Pages:
RE: Low 5v ref - Yukonjay - 02-12-2021 Hey there mr fixkick Thanks for all the info. Couple more quick ones before I fire this pup up again. The mafs got 12v to it So it’s def bad. Ok.... 1-can I wire the sensor ground straight to the battery? 2- can I run the car without the ect maf and o2sensors?... I Caint find anything wrong with any of them or the wiring. Also if I can run without all the sensors in that 5v ref circuit thought I would wire the grey yellow ground separate- straight from ecu to tps to make sure it wasn’t picking any vol anywhere. That way would be eliminating anything but the tps wiring?? Thanks for your help!! RE: Low 5v ref - Yukonjay - 02-12-2021 Uh by not running the sensors I mean I would pull their wires out of the back of the ecu Thanks RE: Low 5v ref - fixkick - 02-15-2021 (02-12-2021, 08:25 AM)Yukonjay Wrote: Hey there mr fixkickinline answers. you do what ever you want to do. it is your car seen these old pig CARS 4WD, used in a forest, tree cut, and log and bucking job , used to drag hug limbs. that are in limphome for ever, 10MPG horror fuel usage like this, and fouled spark plugs every day. some what it to run right others are happy if it make noise and can move say 50ft. logging. what matters top you ive no cue. you are welcome, but we can fix all problems that is for sure and most have big problems., old. RE: Low 5v ref - Yukonjay - 02-15-2021 Hey there mr Fix Think we’ve got our wires crossed on the maf. I do have 12v on the blue black wire to the maf. Got 7 or more at idle on the gray black wire back to ecu. I jus rewired the tps and pulled the o2 ect maf wires out of the ecu harness connector. So far so good. Def does run rich but... runs... so far. Have had it go 3 weeks n then drop my 5v to the tps so we’ll see. I want to prove it’s somewhere in those wires at least so I can start to narrow it down one at a tone somehow. Something interesting is that it used to have a bad lag somewhere bout 3500 rpms before and now it doesn’t? Maybe one of the either grey wire back from tps or blue white wire?? Dunno. Tested these wires and sensors every which way including pulling sensor wires out of ecu connector and sensor and load testing each wire. Haven’t found anything wrong except the maf but even with those wires pulled from back of ecu still would end up dropping my ref. Sooo I got something else goin on somewhere. Thought once this thing runs awhile hopefully. I’d clip my tester to each sensor wire unplugged from ecu. Drive it around for awhile and watch for something out of whack. It’s just so intermittent that seems I’d have to watch each sensor wire for a month In order to rule it out since it’s run just fine for 3 weeks n the past. Something like that. Need a way to watch each sensor and wires for awhile and rule them out. Or... tell me what you think. Rerun All these sensor wires? Guess could still be the sensors so maybe replace these too? Where it’s at now if I drop my ref vol again then it must the ecu power or ground or sensor ground??? I’d love to take each sensor and plug them back to the ecu one at a time but I don’t want to blow another ecu. Thanks for your time and insight there mr RE: Low 5v ref - fixkick - 02-15-2021 (02-15-2021, 03:52 AM)Yukonjay Wrote: Hey there mr Fix7v is bad maf, for sure. (connected assumed) a secret on mAFs, the pin 2 output is a VARIABLE current only output and the 1000 resistor,inside the ECU converts that to voltage.!!!!! this must be under stood first. or maf testing will fail. on 1996+ cars the SCAN too tells me gram/s MASS air flow in the screen. G/S = grams per second flow, a very very important sensor that must work correctly and 7v is NOT IT. if you fail to keep the maf connected pin will LIE to you for sure. proof here, bench tested. see my bench resistor here,? the maf can only tested on car, or like DID below. RE: Low 5v ref - fixkick - 02-15-2021 for you , test the MAF only on the car, and connected never unconnected, to ECU. see my voltages above. in BLUE INK text. (CONNECTED) you must learn that skill called back probing on cars EFI this old, 1996 we can cheat, not you. OBD2 I can see all sensors live data. not you only hard work with meter back probing needel probes, all sensors, (outputs) RE: Low 5v ref - Yukonjay - 02-16-2021 (02-09-2021, 07:42 AM)fixkick Wrote: if blue/black power is dead to maf that bad wire makes the MAF dead, it has no power and will be dead, not a bad mAF just lack of power,. Ok mr, she ran GREAT sat. Now she’s dropped the ref vol AGAIN. Totally rewired tps. Maf ect and o2 pulled from back of ecu. She’s definitely in limp home mode now. Don’t know why it ran so good sat. Didn’t seem to affect it at all that the other sensors weren’t on there but could smell that it was runn rich- lean... something. Wasn’t getting any black smoke. Ummmm. Ref is down to .08 now. Totally lost again.... bad ecu??? Had a rebuilt one in there ran great for couple days without the maf plugged in minus the hiccup at say 3500 rpm then it dropped the ref. This time..sat... it ran even better with the rewired tps...and no maf ect and 02 sensors. Maybe this ecu is shot???? And the other rebuilt one blew because of the bad maf?? Bout ready to scrap this ol girl. Tired of throwing money at it. Definitely appreciate your insight. Thanks RE: Low 5v ref - Yukonjay - 02-16-2021 Also..... I had the ecu on the floor so I could access it for testing. Is it missing a ground by not being screwed in?? RE: Low 5v ref - Yukonjay - 02-25-2021 Ok mr, she ran GREAT sat. Now she’s dropped the ref vol AGAIN. Totally rewired tps. Maf ect and o2 pulled from back of ecu. She’s definitely in limp home mode now. Don’t know why it ran so good sat. Didn’t seem to affect it at all that the other sensors weren’t on there but could smell that it was runn rich- lean... something. Wasn’t getting any black smoke. Ummmm. Ref is down to .08 now. Totally lost again.... bad ecu??? Had a rebuilt one in there ran great for couple days without the maf plugged in minus the hiccup at say 3500 rpm then it dropped the ref. This time..sat... it ran even better with the rewired tps...and no maf ect and 02 sensors. Maybe this ecu is shot???? And the other rebuilt one blew because of the bad maf?? Bout ready to scrap this ol girl. Tired of throwing money at it. Definitely appreciate your insight. Thanks Find Edit Delete Reply Quote Report [b]Yukonjay[/b] Junior Member [img]images/star.png[/img][img]images/star.png[/img] Posts: 8 Threads: 1 Joined: Jan 2021 Reputation: 0 Warning Level: 0% #18 02-16-2021, 05:16 AM Also..... I had the ecu on the floor so I could access it for testing. Is it missing a ground by not being screwed in?? RE: Low 5v ref - fixkick - 02-27-2021 (02-25-2021, 12:00 PM)Yukonjay Wrote: Ok mr,sure seems to me bad +5ref inside ECU, the TPS can not short out, (inside it is pure carbon inside on top pure ceramic base) it will not short. wires yes. nor ECT ,IAT (super rare to short this, but wrong sensors can, here, but some ECT are switches inside, and no good here stolen from other cars, see folks do that, and bad to the bone it is.) most times it is BAD WIRING, and us super common that, on cars this old, ratty nasty wiring. (and there connector pins bad) the MAF can NOT Short out +5vREF, it can not do that, ever , the MAF is a 12vdc powered sensor not 5v. see? all other sensors use 5v directly or indirectly. for sure finding bad ECU or finding any kind of INTERMITTENT short is not easy on any car for sure moving. the +5vref is bad inside the ECU or the loads on it are shorting to ground, if shorted to 12vdc that blows the ECU +Vref up to H3LL. Many ECUs do have bad +5vREF, and is the first test done, and DTCs or Dead CEL lamp. this PC has mode called BACKUP mode, and tons of black smoke (or cat burning up, eating all that crap) Backup mode is like 1960s lawmower engine, no controls at all much. the clue is CEL lamp is totally dead. so now you know the 3 modes of ECU, Backup, Limphome and normal. The ECU does not know why it fails only that it DOES. good luck finding the cause or good used cheap ECU,. rare that. now. |
