Horn does sometimes works, sometimes not - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Horn does sometimes works, sometimes not (/thread-horn-does-sometimes-works-sometimes-not) |
RE: Horn does sometimes works, sometimes not - rasmeidirt - 11-04-2020 (11-03-2020, 10:00 PM)fixkick Wrote:Yes, sometimes it is just a small thing makes the whole world stuck!!(11-03-2020, 03:36 PM)rasmeidirt Wrote:amazing, my posts told you the top reason for horn failure and gee lots of things on the car are the bad suzuki grounds.(11-03-2020, 10:30 AM)rasmeidirt Wrote:Before going to the shop, I decided to check all the ground points in the engine bay, by unbolting them all, the one for the horns is on the right fender next to the airbox, to clean with a wire brush. After bolting back, I start the car and press the horn buttons to my surprise the horns honk!!!!!!!!!(11-03-2020, 10:19 AM)fixkick Wrote:Two shops has already said come back with the clock spring!! Yes the car has two airbags. Thanks for this.(11-03-2020, 09:03 AM)rasmeidirt Wrote: Thanks. Does the steering wheel clock spring really exist?? I checked the two horns and removed them to test with 12v battery. They work!you forget the horns must work on the car, on a bench only proved the horn actual are good. |
