Intermittent Hesitation/Surge Problem - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Intermittent Hesitation/Surge Problem (/thread-intermittent-hesitation-surge-problem) |
Intermittent Hesitation/Surge Problem - 3Waggintails - 02-26-2020 Recently having routine maintenance done on my 97 Sidekick 1.6, 5spd MNL, 4 door Sidekick 16 valve engine. Check engine light had been on in the car intermittently since I got the car in 2015 with 60k original miles on the clock. Never any driveability issues. Gas mileage 24-25 mpg which I felt was good as I do little interstate driving. Don't recall when it became "permanently" on but I got curious while car was in the shop. Mechanic scanned and gave me codes for upstream 02 sensor and P0400 (EGR). Car needed a muffler and I decided to go ahead and take care of 02 sensor issue. Upstream was stripped out and could not be removed form the manifold. Exhaust shop had to create a bung hole in down pipe b4 cat to install. downstream was replaced as well. Had the egr, egr switch tested by mechanic and he said all good. Cleared codes. That lasted 2 days and engine light back on. P0400. Decided to get egr, switch and modulator to replace. Cleared codes. At this point, noticed a slight hiccup at idle but no hesitation, etc good acceleration, etc. Shortly after apparently got bad gas somewhere and was driving on interstate. About 20 miles out, car started "bucking" like a slight power loss. With applied pressure on accelerator would responded and buck again intermittently. Aborted trip and put Heet in tank, drove about 10 miles and fine. Didn't have any other issues. Took to mechanic next day. Engine light still on P0400. Had smoke tested. Only came out at airbox. Checked and cleaned mass air flow. Asked to chnage fuel filter and when they pulled it was full of water - looked like mud. Recommended I drop tank, etc. dump gas and replace fuel pump and strainer as well. Did it. While it was there I had them do plugs, wires, rotor button and distributor cap. Never done since I owned car but also never any issues (current mileage 97k). Drove car over a week and suddenly when driving back from errand about 5 miles from my house when I was accelerating at about 20-25mph, the stutter/hesitation reappeared. Continued to do so for a few blocks then stopped. Called mechanic. No help - slammed. Let car cool off and drove again a couple hours later. Initially no issue BUT appeared that once at operating temp for several miles - approx. 5, the issue would resurface. Continued driving, it would occur intermittently. Now it seems if car sits 10 -15 minutes and then you drive again, once you've gone so many miles or so many minutes at normal operating temp, the stutter hesitation occurs. Speed doesnt seem to matter. Whether your're going 20mph or 60 mph. On same note, it may not do it at all. Car currently in different shop now and they are trying to diagnose. At $117 an hour, I need help and advice. Most places won't even touch old cars. P0400 code still when took in. Never have been able to get rid of it. See attached narrative I gave to mechanic shop.
1997 Suzuki Sidekick Feb 2020 Issues.docx (Size: 14.46 KB / Downloads: 4)
RE: Intermittent Hesitation/Surge Problem - fixkick - 02-26-2020 (02-26-2020, 04:35 PM)3Waggintails Wrote: Recently having routine maintenance done on my 97 Sidekick 1.6, 5spd MNL, 4 door Sidekick 16 valve engine. Check engine light had been on in the car intermittently since I got the car in 2015 with 60k original miles on the clock. 97k, so is a near new car, that low, very very rare that. (I had 2 like that) too bad really that the mech never looked down the tank hole, with PUMP RACK removed, too too bad that.. wow, what MISSED opportunity there.. that mud does not just come from thin air, the tank is bad. (or the fuel rack only rusted out, ??? but only looking matters. EGR 400 fail is caused by 3 things, vacuum path failing or exhaust, (exhaust is always #1) and #3 bad parts, EGR main tops that list ALWAYS. P400 does not a lie the EGR system is failing and can so all the symptoms (not mudd related) stated about. for sure hot RPM below 800PRM hot engine. 750rpm is spec min. the first thing to do is clean out mono-port hole here, EGR port. https://fixkick.com/sensors/EGR/90-95/SLIDE/html/image_12.html then test the EGR main. the EGR main can be bad, that is the device on the rear of Intake man. runner #4 EGR mIAIN. on cold engine not running make sure the ring inside can be pushed, and make the valve open and closed with thunk. test #2, is the stall test.. (best done with hand vacuum tool, no burns) ![]() your car will not have part 36. your car has EGR map system , and works far better than other early ways.. To test EGR nothing works better than having a HAND VACUUM pump to connect to hose 23 , and hot engine pump up say 10HG vacuum and the valve opens and stalls, or RPM falls 800 to 400.. this one test, tells me (passing) that the EGR exhaust paths are not 100% bad, this also is binary search method "diagnosis" , cutting the true possible causes in 1/2, and 1/2 the labor, or MORE. if guessing, just clean the mono port hole and buy a new #5 (far far less work if this fixes it) all tests are here, covering this GEN2 EGR yours is. see the stall test, below... then the bark test. https://fixkick.com/EGR-Gen2a.html try to know that the path for ERG is long, and complex. but on this car less, by 3. Tube 50 can clog;. EGR main #5 can be bad. most are at 100k miles ive seen.. the intake egr ports can be clogged, and the head tunnel EGR and the #4 exhaust port EGR tunnel clogged too. that is why I do test first. to see what we have, see the ring below (push here) if must move cold(hot you get burned ) and the ring moves 1/4" inward keys on pocket test this is JAM test 1. then on the engine running test, hot , I apply vacuum to the missing vacuum nipple below, and engine stalls hot, 800 rpm drops to 400 or less or even stalls.. if yes ,this test passes if the test fails, for stall test, remove hose from bark tube(cold running engine) and it is felt to go PutT PUTT every time #4 cylinder fires. (barking like) if the Bark test if failing remove the egr main below and remove the carbon packup everywhere inside, even the bark tube can pack up. if this test bark still fails then the head or intake tunnels are packed up in carbon. did you buy new MAIN below #5 part? please advise. if yes the ring moves free and stall test passes. if not the bark tube most go putt putt. ![]() bark failures, are here,, red arrow path , end to end, packed in carbon, I can also start the engine below, the feel if the "IN" hOLE BARKS. the out port runs pipe 50 and the mono port injector egr. ![]() the head path is below (bark tunnel) I like naming them to focus clearly. ![]() crazy S here.. and last this, most hard of all to fix. well the above crazy S , hard too. ![]() all 96 up have mono-port EGR injection point , #1 must be cleaned from front to rear (facing bell horn) and at pipe 50. this loves to clog up, "LOVES TO" ![]() the #1 hole here i s 1/2 clogged up, and that is BAD. seen them 100% clogged, and that makes hole Invisible, ( only seems so.) good luck and do ask questions, I can fix this EGR no matter what with testing, for sure easy if tests FAIL HARD< as is so common. RE: Intermittent Hesitation/Surge Problem - 3Waggintails - 02-27-2020 FixKick: Tried to reply but guess I did wrong it says too many images. But images were from your reply. Short and sweet: EGR and switch and modulator replaced with reman, tested parts off ebay. Fuel tank supposedly wiped out, rinsed etc but waiting on mechanic to call me back with specifics. Waiting on current shop to call with infor on what they have found so far. (my regular was too slammed to get car in to look at it). RE: Intermittent Hesitation/Surge Problem - 3Waggintails - 02-27-2020 Well have only heard back from first shop. The exact words I got were that when the tank was totally dropped and drained most of the sediment came out. I was told it was wiped out thoroughly. That's it. No word from current shop on what has been tested etc. I think from talking to office manager, guy is busy and no like to be bothered. Definitely no lengthy conversation. Probably just thinks I am a stupid woman that doesnt know anything and waste his time. granted, I am no mechanic and have to rely on others but if I can provide helpful info on my vehicle, you would think they would appreciate. Based on infor you sent and pics, as well as possibility of having to clean various ports in the intake manifold, that could be very labor intensive and if I can find a shop to do so would be costly. Just like body shops not wnating to fool with bondo anymore, it seems most want to just replace parts rather than rebuild, etc. That being said, my old EGR and switch etc were supposedly working in the first place. Perhaps I can clean the EGR and I did find a used intake manifold but dont know if stilll available. Costly but perhaps I could buy and clea thoroughly myself as well and just have replaced. I am desperate and at a loss. That car is my daily and I love it. No issues until now and I feel like I opened a can of worms by switching the egr, modulator and switch when the originals were supposedly working fine. RE: Intermittent Hesitation/Surge Problem - 3Waggintails - 02-27-2020 Well just talked to second shop and still know NOTHING so far about what they have tried in testing. I forwarded the link to this thread to them as well as some infor from Suzuki forum that one guy had gotten from here. It was pretty concise on the cleaning the egr tube etc. If I can get them to look at this and try it.... Owner drove it for 30 minutes this morning and said it ran great. It does until this crap happens. Just the other day, I had issues on my way to run errands with the hesitation/stutter and absolutely none on the way back! That is what is so confusing and confounding to me. I would think if it was going to have the issue, it would always do it....so I am waiting to hear back from them on what they did so far in testing other than just test driving. RE: Intermittent Hesitation/Surge Problem - fixkick - 02-27-2020 (02-27-2020, 03:55 AM)3Waggintails Wrote: Well just talked to second shop and still know NOTHING so far about what they have tried in testing. I forwarded the link to this thread to them as well as some infor from Suzuki forum that one guy had gotten from here. It was pretty concise on the cleaning the egr tube etc. many shops will not flag the bad rusted, tank, due to not wanting to order a new tank for many reasons. Spectra Premium tanks are plated inside and will not rust. (unlike naked steel tanks do so easy; questions, 1: did you let car sit in the rain with the gas cap removed?; 2: when car runs bad, does the seem violent or smooth loss of power (violent is park bad and smooth is low fuel pressure or 4 clogged injectors) 3: when ca runs poorly , can the fast right foot, make it recover,? lots of these cars now have a bad FPR fuel pressure regulator and love to first intermittent causing loss of fuel pressure, and weak power but is not violent. I can weak power bogging. like walking in a mud pit , can not go fast there. 4: really intermittent problems are not easy to find, (I have even removed the hood 100% off car and drove with my fuel pressure gauge (tool) attached to fuel rail, to see if pressure goes wrong, at poor running, (low pressure bogging, too high flooding and misfiring) if reads wrong FPR test are next. I have also did same with spark timing light attached to #4 spark wire and duct tapped it to my wipers to see if spark goes wonky at the misfiring, point.. tedious but very effective tests. driving and flashing endless that light, (trigger taped ON too, ) 3 wires 2 battery one spark and I can watch spark mess up. if engine misfires, that is what we do. and more. trick 5, drive with OBD2 scan too scanning full time (2 persons testing) see if pending DTC codes POP. "errors" at the time of the poor engine power, Some mechs do not want to go the full haul, and drive the car until it faills some even take your car and us it to drive to work then OMG the nice lady was not crazy.. YOU ARE NOT. RE: Intermittent Hesitation/Surge Problem - 3Waggintails - 02-28-2020 Thanks for the additional information and all of your help! I had to call the shop again late yesterday afternoon and nearly threaten them to get information. I was told the following: 1) they saw two corroded sensors the ones for the coolant temp and the one that tells your cluster temp guage the temp. I knew they were covered in green corrosion but were functioning fine. 2) They said the found a "leak" in the intake manifold. Were not specific. 3) They looked at the old egr (I left in car for themn to see) and said it did not look bad or very dirty at all 4) The were able to reproduce my stutter at idle. Its only a mild hiccup. you can feel it and see it if you look at engine running but not violent at all. 5) Never mentioned the hesitation /surge issue when driving although supposedly drove it 30 minutes. So, this being said, they are going to clean throttle body, remove intake manifold and clean all passages, etc. Replace all needed gaskets/seals. All to the tune of $985 (Includes diagnostic time of ???) So now I see what you just last posted. To answer your questions and to be clear... 1) The car has never stalled and died - inspite of the low idle of 500rpms. Until The prior work was done - egr replaced etc. never a hiccup. 2) when ever the issue occurs, continued pressure on gas pedal and goes or sometimes I may back off pedal and depress again no problem. 3) The issue is not rough for the most part. it just feels sluggish or poor throttle response for a couple seconds, then responds. RPMS not going crazy...speedo may move a litt;e but very minor 2-3 mph difference when it occurs. I foolishly tried to adjust the idle because of low operating RPMS (500) and was afraid it might die on me. So I turned the black plastic screw on top of the throttle body and messed with that. Thats when I got high idle that would take forever to come down. It would eventually get 750-900 range (visually no guages or monitors attached). Then when you sat stopped for a few seconds drop back down to 500. I asked them yesterday to PLEASE pull the fuel filter and cheek if more water, mus crap. No response yet. Going to call shortly and Insist and tell what you said about the regulator, fuel lines/injectors. BTW: I had researched so much, already had FPR on my list in in both carts on Ebay and Amazon - which I could get quicker. Is that very hard to replace? Labor intensive? Also gas cap NEVER left off - locking fuel door - need key. New cap and always turn 3 clicks Kind of at their mercy but work I cannot do and rather just try and get all fixed! Please advise any thing else ASAP! RE: Intermittent Hesitation/Surge Problem - 3Waggintails - 02-28-2020 Also, just to let you know, I feel that they (current shop) read what I forwarded from you that you posted and just jumped on it - but I have no proof. Just miraculously I finally get a response etc. I can't prove it and as I said at their mercy. At same time, perhaps issue will get fixed and I have peace of mind that hopefully will not occur again for a long while! Any way to avoid these issues? Egr stuff etc. Getting bad gas you never know. I pretty much only a couple of nearby stations unless traveling. Also just use regular gas due to budget, etc. |
