Car running horrible flashing code 14 FIXED - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Car running horrible flashing code 14 FIXED (/thread-car-running-horrible-flashing-code-14-fixed) |
Car running horrible flashing code 14 FIXED - Baja_bound - 02-20-2020 My 93 Sidekick 1.6L 16v (G16B MPI) was running real bad, low idle, barely drive in 2nd etc. (limp home?). I used the OBD1 method of paper clip to jumper 2 to 3 and it flashed code 14 (coolant sensor circuit). I took it in and had a diagnostic test done and they found that: "...ECT SENSOR HAS LOW VOLTAGE. VERIFIED THERE IS .5v AT THE ECT SENSOR WITH THE SENSOR UNPLUGGED. TESTED FOR VOLTAGE AT THE ECM AND FOUND 1.5V COMING OUT OF THE COMPUTER. VEIRFIED THE MAIN RELAY IS PROVIDING PROPER POWER AT THE ECM. VEHICLE WILL NEED AND ECM" The mechanic said $800 or to replace the ECM myself and gave me a part number. Very nice of them! I replaced the ECM (ECU) with a Cardone as recommended by fixkick and using the directions provided here. The car runs like a champ now and no codes flashing. The ECU that I pulled out was rusty and had moisture on it from my car leaking. It had a number in yellow paint pen which leads me to believe this was a used part. Hopefully the Cardone lasts longer. My car leaks pretty bad and it rains 76" a year here so I'm still wondering if water damage had anything to do with it or if it was an old ECU on its way out. Not sure if this will help any one but figured I'd share just in case. Tried to post photos but couldn't upload from my computer. RE: Car running horrible flashing code 14 FIXED - fixkick - 02-20-2020 (02-20-2020, 01:03 PM)Baja_bound Wrote: My 93 Sidekick 1.6L 16v (G16B MPI) was running real bad, low idle, barely drive in 2nd etc. (limp home?). I used the OBD1 method of paper clip to jumper 2 to 3 and it flashed code 14 (coolant sensor circuit). I took it in and had a diagnostic test done and they found that:is this card 2door, rag top, ? you said water leaks, but why are there water leaks, bad window..front glass???? but yah water and electronics is never ever any good. The ECU is self protected from say fog, or high humidity not floods, not ever that. SENSOR UNPLUGGED. 0.5v, that means ALSO, the wires to it or cut or shorted...... not just the ECU. but you found it was ECU. the car new, had a plastic cover cover #3 the top of the ECU, so if say window cracks water does not wreck the ECU. missing now, and yellow marks from used ECU from the wrecking yards. The ECU Pin B6 must have +5vdc there, or the 5v regulator in the ECU is blown out, this makes sensor go dead, many run on 5vdc.. so.... there is that, if you keep car dry the ECU can last 20 years easy. (with good CAPs inside from JAPAN) your car is 26 years old, on newer car , say JEEP these damage would go over $3000 , with many front controllers are damaged, lucky you your old car has only 1 computer. the days of simple cars with 2 wire ignition and A Carb are sadly gone. in the old days they said, "keep your powder dry" ,noW it's puter dry. and is way of saying GOOD LUCK PARTNER.. RE: Car running horrible flashing code 14 FIXED - fixkick - 02-20-2020 AS SIDE JOB is BUY A USED ecu FOR NILL (MATCH THE ENDING # TO YOUR CAR, NOT TOLD YET, IS YOUR CARD 2 DOORS? MATTERS ON ECU AND HOOD STICKER WORDS TOLD) DO YOU HAVE 5 SPEED MANUAL BOX? TRANNY, Only clue is driving in 2nd, gear, this to matters buying any ECU, engine,trans, doors and 4wd.. (2 engines that year yours is 16v) AND RECAP IT, 33920-58Bxx ( my guess yours is the 58Bxx series, what is xx on your ECU? https://www.ebay.com/sch/i.html?_from=R40&_nkw=SUZUKI+TRACKER+ECU+1994&_sacat=0&_sop=15 ~58B30 fed, 93 58B10 is calif. 93. , the 58B30 car has on IAT (air temp )( sensor on the side of the Air cleanerbox. (mixing these 2 up wrong gets you IAT errors.) above is MT box only, Manual tranny. Here they all are 89-95 PDF Id never own any of these cars, with no spare ECU, and can be had cheap and recapped for 5 bucks. (from mouser.com and japan caps from NIchicon) just buy them with a NO DOA, promised, by them, then recap it. cheers....... RE: Car running horrible flashing code 14 FIXED - Baja_bound - 02-21-2020 It's a 1993 Sidekick JX, 16v, four door, 5-speed, hard top. (I tried to make an info signature but is "forbidden") The leaks come from the moonroof and/or the the windshield. Also the drivers side windows and possibly the rear door leak. It was involved in an accident before I bought it but since it's going to live in the desert eventually I was not too concerned about the leaks. Oops. I've owned about 10 months. Guy who sold it told me it didn't leak. Guy also painted over CEL so, yeah. I bought a car cover for it a week ago but it already had a small pond in it (dry now though). The number on the ECU is 33920-58B3(0) Thanks for all the info and I'll definitely look for the plastic cover as mine was gone like you guessed. Photos: https://drive.google.com/file/d/17_yshwxWKXk364PoW0bZuxmcrXaewrlz/view?usp=sharing https://drive.google.com/file/d/1dg6oBU_kDszNyFgVA3thvcEX2upYxpYa/view?usp=sharing RE: Car running horrible flashing code 14 FIXED - fixkick - 02-21-2020 great a B30 ECU, FEderal ECU, no MT, no CALIF junk here. 92-93, fed. 4door ECU it is. a match that. NO AIT sensor car, (on AIr cleaner box) no EGRT, one more part to fail not there, on B30 and uses vacuum to see if EGR works. you might just for now use plastic bag folded and stuff above the ECU for water shield, DIY home grown, for sure Im glade the car runs now, and better. make sure ECU lid IS UP and not down. oops. make sure plastic bag blocks water to the wired JACKs there. pas thanks for sharing photos, nice.. cheers. |
