Catalytic Converter, O2 Sensor & EGR Questions - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Catalytic Converter, O2 Sensor & EGR Questions (/thread-catalytic-converter-o2-sensor-egr-questions) |
RE: Catalytic Converters Questions - Von - 03-01-2020 (03-01-2020, 10:11 AM)fixkick Wrote:Yes I meant .005-.007 compression is good and timing good prior. Before there was no cat and EGR was not connected now there is new cat and EGR not connected. Could EGR be the reason why now with the new cat that it is not starting?(03-01-2020, 09:30 AM)Von Wrote:THE EGR REMOVED LEAVES A HUGE HOLE IN THE INTAKE, VERY BAD THAT.(02-20-2020, 11:45 PM)Wi fixkick Wrote: SOME of those headers made by Doug thorley are not made now (too few cars on road running I guess)My header does have that slot. Also to bring you up to speed where I am at with it now, I got the new cat. It is not melted and is installed properly now. PO removed. Prior to that I checked main cog for damage, replaced the pugs gapped .28 and wires installed properly, I replaced the timing belt but did not move the main and cam crank independently, I set valve lash to .06 but they were only off at .05 and or 0.07 so not much adjustment. The vehicle ran before but will Crank and not start now. RE: Catalytic Converters Questions - fixkick - 03-01-2020 (03-01-2020, 11:34 AM)Von Wrote:what does not connected mean?(03-01-2020, 10:11 AM)fixkick Wrote:Yes I meant .005-.007 compression is good and timing good prior. Before there was no cat and EGR was not connected now there is new cat and EGR not connected. Could EGR be the reason why now with the new cat that it is not starting?(03-01-2020, 09:30 AM)Von Wrote:THE EGR REMOVED LEAVES A HUGE HOLE IN THE INTAKE, VERY BAD THAT.(02-20-2020, 11:45 PM)Wi fixkick Wrote: SOME of those headers made by Doug thorley are not made now (too few cars on road running I guess)My header does have that slot. Also to bring you up to speed where I am at with it now, I got the new cat. It is not melted and is installed properly now. PO removed. Prior to that I checked main cog for damage, replaced the pugs gapped .28 and wires installed properly, I replaced the timing belt but did not move the main and cam crank independently, I set valve lash to .06 but they were only off at .05 and or 0.07 so not much adjustment. The vehicle ran before but will Crank and not start now. there are 3 things (up to) mounted EGR main, to rear or intake runner #4 (now it cant leak mounted) one vacuum hose. and one bark tube to the modulator valve 95 and older has 4th things the EGRT thermal sensor. if you have good and fully closed EGR min and leave the vacuum tube not connected but use golf TEE to plug the vacuum sucking hose, the EGR is now off line, and out of the pictures so if spark timing is correct , test fuel will fork, proving it runs for 3 seconds each spray session. (can of instant start in a can sprayed.) RE: Catalytic Converters Questions - Von - 03-01-2020 (03-01-2020, 01:23 PM)fixkick Wrote:Not connected as in the vacuum lines and wire was connected but the EGR was not bolted to the engine.(03-01-2020, 11:34 AM)Von Wrote:what does not connected mean?(03-01-2020, 10:11 AM)fixkick Wrote:Yes I meant .005-.007 compression is good and timing good prior. Before there was no cat and EGR was not connected now there is new cat and EGR not connected. Could EGR be the reason why now with the new cat that it is not starting?(03-01-2020, 09:30 AM)Von Wrote:THE EGR REMOVED LEAVES A HUGE HOLE IN THE INTAKE, VERY BAD THAT.(02-20-2020, 11:45 PM)Wi fixkick Wrote: SOME of those headers made by Doug thorley are not made now (too few cars on road running I guess)My header does have that slot. Also to bring you up to speed where I am at with it now, I got the new cat. It is not melted and is installed properly now. PO removed. Prior to that I checked main cog for damage, replaced the pugs gapped .28 and wires installed properly, I replaced the timing belt but did not move the main and cam crank independently, I set valve lash to .06 but they were only off at .05 and or 0.07 so not much adjustment. The vehicle ran before but will Crank and not start now. RE: Catalytic Converters Questions - fixkick - 03-01-2020 (03-01-2020, 01:27 PM)Von Wrote:test fuel test, pass/fail(03-01-2020, 01:23 PM)fixkick Wrote:Not connected as in the vacuum lines and wire was connected but the EGR was not bolted to the engine.(03-01-2020, 11:34 AM)Von Wrote:what does not connected mean?(03-01-2020, 10:11 AM)fixkick Wrote:Yes I meant .005-.007 compression is good and timing good prior. Before there was no cat and EGR was not connected now there is new cat and EGR not connected. Could EGR be the reason why now with the new cat that it is not starting?(03-01-2020, 09:30 AM)Von Wrote: My header does have that slot. Also to bring you up to speed where I am at with it now, I got the new cat. It is not melted and is installed properly now. PO removed. Prior to that I checked main cog for damage, replaced the pugs gapped .28 and wires installed properly, I replaced the timing belt but did not move the main and cam crank independently, I set valve lash to .06 but they were only off at .05 and or 0.07 so not much adjustment. The vehicle ran before but will Crank and not start now.THE EGR REMOVED LEAVES A HUGE HOLE IN THE INTAKE, VERY BAD THAT. if compression is ok , engine will run on test fuel, if spark is good. any gas/petrol engine. (car/truck,lawn mower, outboard motor, motor cycle, and more) watch scotty. (he used the IAT sensor hole. ) https://youtu.be/064Ilsz8Fzg?t=31 vw (no gas tank at all , it runs) like this, ) V-DUB. https://www.youtube.com/watch?feature=player_detailpage&v=HhXwVhYfPm8#t=141s https://fixkick.com/sensors/tests/runs-on-test-fuel-only.html conditions,
RE: Catalytic Converter & EGR Questions - fixkick - 03-01-2020 94 Suzuki Sidekick JLX 4x4 with a 1.6L 16v engine. that new Exhaust manifold. has no EGR tube, and is the old old NON USA/CALIF non EPA/CARB version, so....... REDUX, back to post #1 94 Suzuki Sidekick JLX 4x4 with a 1.6L 16v engine. I guess you never seen the car run before, not mentioned in post #1, if it did not say so and we time the engine right, as your PO my have all this wrong , as many do. so just defeat the EGR, make sure it is closed in side and no leaking, and mount it, (for prosperity) and just remove the vacuum line and GOLF TEE the end so the hose can NOT SUCK AIR. if the EGR is not stuck open it can not cause failure to start. can not. (it has its own spring inside, that keeps it closed forever, if you defeat the vacuum line that is. per above. then do the test fuel tests. when you work on the cam belt. did you use the right markings if not compression fails and spark timing will be all wrong, do NOT USE "I" marks, for key or timing mark see below. the bottom crank mark is at 12PM. cog and top on oil pump marked) if this is done right the spark is next. error #1 by many PO/'s is using 8v wiring order for 16v engine, and will NEVER run again. Timing a Distrib is just like some old 1960s Chevy V8. the disrib is gear driving 13 teeth (IIRC) the timing steps are here (full) https://fixkick.com/16v-ignition-timing the simpler way
seen these cars with C4 china junk parts rotor that fits on 3 ways, DOOMED that, buy real parts, this is my first look thing, the bottom of the rotor (REAL) has spring clip that blocks all ways of doing it wrong 2 wrong 1 right. this is good rotor. compression spec, on this engine is The 16v is 195 PSI. Seen in FSM chapter 6-6 (not 6A1) (never 100 , never 50) if all are low the cam belt is wrong. warm engine at sea level. and throttle must be blocked open some or more, air starvation makes readings wrong. RE: Catalytic Converter & EGR Questions - Von - 03-02-2020 (03-01-2020, 10:23 PM)fixkick Wrote: 94 Suzuki Sidekick JLX 4x4 with a 1.6L 16v engine.Ok looks like I’m starting over from scratch. The engine ran when I got it. I have seen it run and driven it. I timed it based off of the info from your forum and pages, I never moved the cam and crank pulleys independently. I put the plugs back the way the PO has them originally. I will be starting over verifying everything from the beginning. And will let you know how it goes. RE: Catalytic Converters Questions - Von - 03-02-2020 (03-01-2020, 10:11 AM)fixkick Wrote:(03-01-2020, 09:30 AM)Von Wrote:THE EGR REMOVED LEAVES A HUGE HOLE IN THE INTAKE, VERY BAD THAT.(02-20-2020, 11:45 PM)Wi fixkick Wrote: SOME of those headers made by Doug thorley are not made now (too few cars on road running I guess)My header does have that slot. Also to bring you up to speed where I am at with it now, I got the new cat. It is not melted and is installed properly now. PO removed. Prior to that I checked main cog for damage, replaced the pugs gapped .28 and wires installed properly, I replaced the timing belt but did not move the main and cam crank independently, I set valve lash to .06 but they were only off at .05 and or 0.07 so not much adjustment. The vehicle ran before but will Crank and not start now. I found that the IG Coil fuse under the dash (15 amp) on drivers side kept popping every time I start the engine. I disconnected the O2 sensor, replaced the fuse and started the sidekick. It fired right up. Now I need to figure out the correlation between the O2 sensor and the coil fuse. The O2 sensor was brand new Bosch unit and I installed it when the I installed the Doug Thorley header. The old O2 that I removed did not pop the fuse so I’m thinking it is the Sensor. How can I troubleshoot this O2 sensor. Also side not with the EGR valve still out exhaust blew out the back of the block so it tells me the in engine pathways are still open. Also exhaust out the rear tailpipe tells me the used cat I got is not clogged. This info doesn’t really matter to this part of the post it just makes me happy. RE: Catalytic Converters Questions - fixkick - 03-02-2020 (03-02-2020, 09:17 AM)Von Wrote:when the IG coil fuel blows the CEL lamp goes dead, ECU is dead, and spark and injections dead, and test fuel would fail I assumed you checked spark and the lamp, sorry(03-01-2020, 10:11 AM)fixkick Wrote:(03-01-2020, 09:30 AM)Von Wrote:THE EGR REMOVED LEAVES A HUGE HOLE IN THE INTAKE, VERY BAD THAT.(02-20-2020, 11:45 PM)Wi fixkick Wrote: SOME of those headers made by Doug thorley are not made now (too few cars on road running I guess)My header does have that slot. Also to bring you up to speed where I am at with it now, I got the new cat. It is not melted and is installed properly now. PO removed. Prior to that I checked main cog for damage, replaced the pugs gapped .28 and wires installed properly, I replaced the timing belt but did not move the main and cam crank independently, I set valve lash to .06 but they were only off at .05 and or 0.07 so not much adjustment. The vehicle ran before but will Crank and not start now. o2 short deal is super common on all cars for sure this old. 1: wrong O2 used (uses special 4 wire o2) see link below for the evolution of EGR on this car, COMPLEX it is. changing 6 times and some with an 02 relay and shorts there. 2: wired wrong, 3: wires to it melted due to lost suzuki tie back clamps the wires hit header melt and short. 4: bad O2. (not if new and made by BOSCH.) I have page covering just them. (varies by year, and Calif/Fed rules) complex. but my charts will tell you what you have. https://fixkick.com/sensors/OxyGen_sensor_help.html#unified RE: Catalytic Converter, O2 Sensor & EGR Questions - fixkick - 03-02-2020 first find out if the car is CALIF or Federal car, hood sticker missing?, makes that hard the old 02, has plug, fed is 3 wires and one blank pin of a 4 pin connector Calif is 4 wires and 4 populated pins. with white connector and flat pins the fed 3 wire connector is black an was round pins. hope you have the old sensor intact, with connector still. the bosch universal hand wire sensors are good too. 15726-3F (for sure most common sold car 48 states.) but only looking first counts. 15730-4C last 2 digits above are mine 3 mean 3 wire, F means federal sold as low as $20 a real money saver. sans connector stock with adapter, RE: Catalytic Converter, O2 Sensor & EGR Questions - Von - 03-03-2020 (03-02-2020, 09:59 PM)fixkick Wrote: first find out if the car is CALIF or Federal car, hood sticker missing?, makes that hard The old had white connector and flat pins. It also had 4 wires. The new one was a universal that required me to splice Into the old wire with the connector side. The new had a blue (signal) white (ground) 2x black (both heater.) The old wire with the connector had the same color wires (blue, white, 2x black) the only ones that could be swapped are the black wires but have been told it doesn’t matter for those. Is there any diagram that shows on the connector end what the 4 wire are called or are for so I can confirm the proper wires were spliced to the right spots. Also I was told that the 2 black wires did not matter which one went to which. Does that matter or could they be swapped. |
