Engine coolant flow - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Engine coolant flow (/thread-engine-coolant-flow) |
Engine coolant flow - Dewmore - 01-18-2020 this Have removed water pump and have found the coolant passages on right side plugged with crud and other sediment. The small passages upper and lower. Can anyone furnish the information where this flow would have traveled. This is a 98 tracker 1.6 16 v. Have just purchased knowing it had a coolant problem. No circulation, first thought thermostat, crud and rust can be seen in picture from storage RE: Engine coolant flow - fixkick - 01-18-2020 (01-18-2020, 09:53 AM)Dewmore Wrote: this Have removed water pump and have found the coolant passages on right side plugged with crud and other sediment. The small passages upper and lower. Can anyone furnish the information where this flow would have traveled. This is a 98 tracker 1.6 16 v. Have just purchased knowing it had a coolant problem. No circulation, first thought thermostat, crud and rust can be seen in picture from storage in the main web page, are two topics, one is overheating, and the other is frigid cooling. its is all there, to see. see 16v valve detailed photo I made, long ago, (overs 8v and 16v and j18 DOHC sport.. https://fixkick.com/overheating.html why not just back flush it? using a water hose to garden water faucet.. the AF we just send to the recycles. Anitfreezecoolant |
