Coolant loss - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Coolant loss (/thread-coolant-loss) |
Coolant loss - GFO4501 - 01-05-2020 Anybody had a problem with coolant loss through the gasket between throttle body and intake? I have a 92 8valve and still seem to be losing coolant after replacing head gasket and intake to head gasket and having head reworked and pressure tested. Compression is ok at around 150 to 160 on all cylinders. No external leaks but the exhaust steams off and on when the engine is hot. The engine runs good and idles good most of the time. It will idle rough momentarily, but then smooth out. Any ideas? Thanks, Greg RE: Coolant loss - fixkick - 01-05-2020 (01-05-2020, 10:28 AM)GFO4501 Wrote: Anybody had a problem with coolant loss through the gasket between throttle body and intake? I have a 92 8valve and still seem to be losing coolant after replacing head gasket and intake to head gasket and having head reworked and pressure tested. Compression is ok at around 150 to 160 on all cylinders. No external leaks but the exhaust steams off and on when the engine is hot. The engine runs good and idles good most of the time. It will idle rough momentarily, but then smooth out. Any ideas? the loop can leak anywhere, but if it lands in the exhaust , and not to the ground. sure bad gaskets. was the head checked for warp, and block deck.? when did it last no leak? white head off, no cracks seen in the cylinder walls? seems it all pressure tested so should be good. leaving only warps and gaskets. RE: Coolant loss - GFO4501 - 01-05-2020 (01-05-2020, 09:50 PM)fixkick Wrote:(01-05-2020, 10:28 AM)GFO4501 Wrote: Anybody had a problem with coolant loss through the gasket between throttle body and intake? I have a 92 8valve and still seem to be losing coolant after replacing head gasket and intake to head gasket and having head reworked and pressure tested. Compression is ok at around 150 to 160 on all cylinders. No external leaks but the exhaust steams off and on when the engine is hot. The engine runs good and idles good most of the time. It will idle rough momentarily, but then smooth out. Any ideas? RE: Coolant loss - GFO4501 - 01-05-2020 (01-05-2020, 11:07 PM)GFO4501 Wrote:I checked the top of the block with a straight edge and also used a dye penetrant to check for cracks. Cylinder walls looked good. Intake gasket surface was flat and head was machined flat. I thought the throttle body gasket may be leaking. Thanks, Greg(01-05-2020, 09:50 PM)fixkick Wrote:(01-05-2020, 10:28 AM)GFO4501 Wrote: Anybody had a problem with coolant loss through the gasket between throttle body and intake? I have a 92 8valve and still seem to be losing coolant after replacing head gasket and intake to head gasket and having head reworked and pressure tested. Compression is ok at around 150 to 160 on all cylinders. No external leaks but the exhaust steams off and on when the engine is hot. The engine runs good and idles good most of the time. It will idle rough momentarily, but then smooth out. Any ideas? RE: Coolant loss - fixkick - 01-06-2020 (01-05-2020, 11:16 PM)GFO4501 Wrote:so the RAD bottle is going low each day?(01-05-2020, 11:07 PM)GFO4501 Wrote:I checked the top of the block with a straight edge and also used a dye penetrant to check for cracks. Cylinder walls looked good. Intake gasket surface was flat and head was machined flat. I thought the throttle body gasket may be leaking. Thanks, Greg(01-05-2020, 09:50 PM)fixkick Wrote:(01-05-2020, 10:28 AM)GFO4501 Wrote: Anybody had a problem with coolant loss through the gasket between throttle body and intake? I have a 92 8valve and still seem to be losing coolant after replacing head gasket and intake to head gasket and having head reworked and pressure tested. Compression is ok at around 150 to 160 on all cylinders. No external leaks but the exhaust steams off and on when the engine is hot. The engine runs good and idles good most of the time. It will idle rough momentarily, but then smooth out. Any ideas? well that is the only gasket and the intake man gaskets that do mix air and water (and must not the 3speed A/T tranny is the worse on any 8v, TB has 2 gaskets on this beast. and heater there. the hole to water is not close. see all views of TB here and gaskets at the end.8v https://fixkick.com/IDLE-AIR/Slide_Show/HTML/image_16.html RE: Coolant loss - GFO4501 - 01-06-2020 (01-06-2020, 02:16 AM)fixkick Wrote:Thanks, I’ll investigate this angle a little further. Greg(01-05-2020, 11:16 PM)GFO4501 Wrote:so the RAD bottle is going low each day?(01-05-2020, 11:07 PM)GFO4501 Wrote:I checked the top of the block with a straight edge and also used a dye penetrant to check for cracks. Cylinder walls looked good. Intake gasket surface was flat and head was machined flat. I thought the throttle body gasket may be leaking. Thanks, Greg(01-05-2020, 09:50 PM)fixkick Wrote:(01-05-2020, 10:28 AM)GFO4501 Wrote: Anybody had a problem with coolant loss through the gasket between throttle body and intake? I have a 92 8valve and still seem to be losing coolant after replacing head gasket and intake to head gasket and having head reworked and pressure tested. Compression is ok at around 150 to 160 on all cylinders. No external leaks but the exhaust steams off and on when the engine is hot. The engine runs good and idles good most of the time. It will idle rough momentarily, but then smooth out. Any ideas? |
