1989/90 , new free(?) ISC gasket. printed - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1989/90 , new free(?) ISC gasket. printed (/thread-1989-90-new-free-isc-gasket-printed) Pages:
1989/90 , new free(?) ISC gasket. printed - fixkick - 11-08-2019 Hallo. (quoted) he can not post due to java-script errors unknown) Thanks so much for your interesting and exhaustive forum. I could repair my 89 vitara troubles. I had the ISC gasket destroyed so not possible to regulate the throttle. So I printed a 3d gasket with TPU material and mounted. It run smooth and perfectly now. you can find the file (.STL) to be printed with exact dimension here https://www.thingiverse.com/thing:3958324 o unfortunately I was not able to publish a post. Have Fun! Thanks , to, HAPPYNEWSUZUKI nice work there and 10x thanks for sharing !!! RE: 1989/90 , new free(?) ISC gasket. printed - fixkick - 11-09-2019 Android+chrome....works RE: 1989/90 , new free(?) ISC gasket. printed - fixkick - 11-09-2019 IE11, logged in, works(w10-64bit) older IE are banned now, not sure here but for sure XP and banks using any OLDer IE. RE: 1989/90 , new free(?) ISC gasket. printed - HAPPYNEWSUZUKI - 11-09-2019 (11-09-2019, 12:33 AM)fixkick Wrote: IE11, logged in, works(w10-64bit) older IE are banned now, not sure here but for sure XP and banks using any OLDer IE. this is a mistery I can't post...
RE: 1989/90 , new free(?) ISC gasket. printed - fixkick - 11-09-2019 (11-09-2019, 04:00 AM)HAPPYNEWSUZUKI Wrote:(11-09-2019, 12:33 AM)fixkick Wrote: IE11, logged in, works(w10-64bit) older IE are banned now, not sure here but for sure XP and banks using any OLDer IE. what to you mean, your posted right now? PM works and you posted just above, what does not work? tell more.?
RE: 1989/90 , new free(?) ISC gasket. printed - HAPPYNEWSUZUKI - 11-09-2019 (11-09-2019, 05:27 AM)fixkick Wrote:(11-09-2019, 04:00 AM)HAPPYNEWSUZUKI Wrote:(11-09-2019, 12:33 AM)fixkick Wrote: IE11, logged in, works(w10-64bit) older IE are banned now, not sure here but for sure XP and banks using any OLDer IE. Could make one replay only.... RE: 1989/90 , new free(?) ISC gasket. printed - HAPPYNEWSUZUKI - 11-09-2019 (11-09-2019, 05:38 AM)HAPPYNEWSUZUKI Wrote:may be two. seems to be a time limit(11-09-2019, 05:27 AM)fixkick Wrote:(11-09-2019, 04:00 AM)HAPPYNEWSUZUKI Wrote:(11-09-2019, 12:33 AM)fixkick Wrote: IE11, logged in, works(w10-64bit) older IE are banned now, not sure here but for sure XP and banks using any OLDer IE. RE: 1989/90 , new free(?) ISC gasket. printed - HAPPYNEWVITARA - 11-10-2019 Just another test with new account , xp pc , firefox... hei hei hei, it seems working now. So update to the vitara 89 fixing. Yesterday I went out for the first ontheroad test. The sidekick run nicely and good power to wheels . I made 91km and some in offroad with 4x4. Good power to the ground and the total consumption was 11.7km/L that is good for a 4x4. The only boring thing is the ISC valve rattle while automatic regulate to 1000rpm in case of front head lights or blow heater on. The noise (rattle) is olso for some seconds while opening the throttle valve to acelerate. But as I read on this forum it seems to be a normal defect. Another issue I could see while in 4x4L mode and turning the stearing left or right the left wheel is producing a cranck noise so think I have trouble on the trasmission joint . May bee on the manual wheel trasmission insertion. Will investigate and will tell Justo to show you the way I used to calibrate idle air on a small 50$ scopemeter I post here the link to some pictures. The DSO nano is nice for this test as it has the automatic reading of the dutycycle and the isolated ground to avoid destructive ground loop. https://ibb.co/0swPS6f https://ibb.co/wYkTfyw RE: 1989/90 , new free(?) ISC gasket. printed - fixkick - 11-10-2019 (11-10-2019, 08:58 PM)HAPPYNEWVITARA Wrote: Just another test with new account , xp pc , firefox... RE: 1989/90 , new free(?) ISC gasket. printed - HAPPYNEWVITARA - 11-10-2019 I can say that bynow the ISC gasket I 3D printed in TPU material (thermal Poly urethane) is resisting nicely to temperature and gasoline vapour. Will report if any fail. Just link here the source for the gasket https://www.thingiverse.com/thing:3958324 Hope it helps someone Have fun!
