2006 jeep liberty timing chain - Printable Version
+--- Thread: 2006 jeep liberty timing chain (/thread-2006-jeep-liberty-timing-chain)
Pages: 1 2 3
RE: 2006 jeep liberty timing chain - fixkick - 08-14-2019
if the cam chain sounds ok, not thrashing sounds.
then replace the CMP next $15 part.
the SMP has new guts, (maker) and a new filter to prevent false readings, I highly recommend the SMP brand of sensor from rockauto or any car store that has them in stock.
STANDARD MOTOR PRODUCTS PC244 (SMP)
the cam has star wheel, with teeth the CMP measure those teeth and uses it to know when to spark and inject.
if the chain is loose, the wheel jogs, causing CMP to see jumping, and the PCM will not like that.
if the sensor gets dirty it also does that , the tip can grow what I call mud on tip, (dirt and super fine iron dust ) this iron dust disturbs the magnetic pulses from the CMP.
just cleaning any speed sensor on any car can be a fix, amazing facts of life.
if you see mud there, just wipe it off, and drive, see?
this job is 15min job. pull it , wipe it , put it back
if fails still put a SMP there new.
This SMP is newer class of smarter better sensors, be sad to see cost of new chain for mud there or bad sensor.
for 15 minute work. and one simple wrench, hardly bent over to reach. take out bolt and twist it cw and ccw, gently to break the dirty gummy seal there.
the new chain is an all day job.
and getting done an not causing new huge oil leak, is not easy, so mech, may charge 2 times that. as insurance.
if you need the pages on the job I have it.
the chain test , in the FSm shows removing the front cover, this is hard work that and long
and most shops just replace the chain doing all that hardwork just to look for execessive 15mm play.
in short, page 4093 of 6059 (yes huge manual, on complex cars today)
coolant drained
fan out
all hoses to cover out.
belts off
crankshaft damper off
alternator off
AC compressor off or retracted.
remove 13 bolts on cover.
the cover is glued on with RTV , removing it and not causing damage takes skills.
new chain per this page , 15 more steps
put back cover, with new RTV gray code. MoparT Grey Engine RTV sealant
a cam locking device ,tool is needed.
I stop here, just to show how hard it is, yes all day long. easy. do it slow and carefully and it will not leak, if not , do over.there is NO GASKET here, so, skills are PARAMOUNT.
RE: 2006 jeep liberty timing chain - star2525 - 03-22-2021
I still have the Jeep and running in Limp home with cell light on constant and not flashing.
Brother had me take it to a Mechanic he knew and the Mechanic quickly pointed out that a head had been replaced.
My brother asked on a Forum about the head and it throwing the cam code and crank code. Someone told him the heads don't line up. And they might be 2 different heads. Guy I purchased it from was taking parts off a 2003 or 2004 Liberty.
I was told the 2005 and 2006 have different heads than the earlier years.
Is it possible that all I need to fix this vehicle is the correct head? And would I need to replace anything else?
Also would like to know if a fuel pump is going bad will I get a code for that?
RE: 2006 jeep liberty timing chain - fixkick - 03-23-2021
(03-22-2021, 02:16 PM)star2525 Wrote: Also would like to know if a fuel pump is going bad will I get a code for that?
hello Victoria. (the V6?engine?)
no codes told P0xxx or P1xxx  or P2xxx DTC codes. , need exact codes to be smart here.
the timing chain must not be bad, or this smarter ECU (PCM) will in fact send out (seems false but not) crank and cam sensor errors.
all it knows is the 2 do not agree!!!, and is a loose chain.  (also reports as the to are not Congruent "differ")
fuel pump bad, may send a code, even if not direct code you will get
1: hard starts.
2: engine stalls
3: engine lacks power.
4: lean codes for P017x code for fuel mix wrong.
the chain on all older engines near 200k miles may be bad. (loose) and the guides.
with that new head was  chain job done, I bet not.  it is a hard job this, for sure no oil leaks after, hard to crack a Brazil nut job.
