Popping sound in air intake - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Popping sound in air intake (/thread-popping-sound-in-air-intake) |
Popping sound in air intake - Pedrofski - 08-10-2019 89 SK. 1.6 it makes a popping sound in intake when started,it goes away after a couple minutes but it comes back if I turn on the lights or fan. Any ideas. P RE: Popping sound in air intake - fixkick - 08-10-2019 (08-10-2019, 02:59 AM)Pedrofski Wrote: 89 SK. 1.6 it makes a popping sound in intake when started,it goes away after a couple minutes but it comes back if I turn on the lights or fan. Any ideas. P if not backfiring to the intake (bad cam timing , spark timing way off or burned intake valves) the noise common is ISC there on top see those 2 wires on top the TB>? if the ISC is bad, it will make noise, they all do this old.? but take it off and hit it with penetrating oil (never wd40) it is just and air valve modulated 200 times a second after 25 years and 10million cycles, it gets loose and makes noise. (many posts same) the deal with HL on blower on or AC on, the ECU raises idle speeds to 1000rpm(or near) and the ECU changes the PWM modulation on the ISC to raise idle. so with any change of idle speed, that noise can change. but be warned cleaning it and lubing it like that, might make more noise. (who knows for sure on old worn out parts)? good luck on that 89. RE: Popping sound in air intake - Pedrofski - 08-10-2019 (08-10-2019, 05:14 AM)fixkick Wrote:(08-10-2019, 02:59 AM)Pedrofski Wrote: 89 SK. 1.6 it makes a popping sound in intake when started,it goes away after a couple minutes but it comes back if I turn on the lights or fan. Any ideas. P That is it. Just unhooked one wire from ISC and noise goes away. Everything seems to work fine with it un hooked is there any reason I can’t leave it unhooked? Thank you much for the info. P RE: Popping sound in air intake - fixkick - 08-10-2019 (08-10-2019, 08:51 AM)Pedrofski Wrote:(08-10-2019, 05:14 AM)fixkick Wrote:(08-10-2019, 02:59 AM)Pedrofski Wrote: 89 SK. 1.6 it makes a popping sound in intake when started,it goes away after a couple minutes but it comes back if I turn on the lights or fan. Any ideas. P it does many things, it keeps engine from stalling with max GEN load on the engine, (headlamps, heater blower-on, defrost on, AC on) and if you have AT transmission prevent stall shifting to DRIVE from PARK. and prevents neck snap, as you decelerate hard, or downshifted. it also work in conjunction with EGR. with no ISC there will be no idle regulation again, ever. (hot) as they say ,,you will find out. all cars have this 89-2019 and beyond. and far worse FLY by wire now, (no throttle cable!, so the ISC runs the engine throttle with wires, and electric motor.) RE: Popping sound in air intake - Pedrofski - 08-10-2019 Thanks for your help. I’ll see if I can track down a new one. Thanks again. P |
