Truck randomly doesn't want to start, will later. - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Truck randomly doesn't want to start, will later. (/thread-truck-randomly-doesn-t-want-to-start-will-later) Pages:
Truck randomly doesn't want to start, will later. - toolman21 - 03-26-2019 1989 Suzuki Sidekick 1.6/5-speed This is driving me insane. Truck cranks and runs normally. I drive it, all works as expected. If I turn it off, sometimes it starts again, sometimes it doesn't. Yesterday I drove it. Came home turned it off. Immediately started it again and it started normally. Turned it off, immediately tried to start again and nothing. It turns over, but never starts. Luckily it finally did it in my driveway so I could troubleshoot the thing. Injector is pulsing gas, I have fire to the plug wires. Pulled the plugs and they look normal. Just spins with the starter doesn't even pretend to try. I messed around with it not starting checking different things until it was cool, still not starting. It isn't flooding, tried cranking with the throttle wide open. Nothing. I went inside, came out 2-3 hours later. Truck started normally again. It has fuel and fire. What am I missing with this thing that it randomly starts or doesn't? Thanks. RE: Truck randomly doesn't want to start, will later. - fixkick - 03-26-2019 (03-26-2019, 05:05 AM)toolman21 Wrote: old cars are like that, ever see any other 89s on the road now, very very rare here, 1 a month if ever, but can be repaired. RE: Truck randomly doesn't want to start, will later. - toolman21 - 03-26-2019 Plenty of spark on all 4 plug wires, checked with screwdriver arced off metal on engine. I took intake runner tube off, the injector is clearly pumping gas when trying to start. Brand new fuel pump, etc. I have spark, I have fuel, just randomly decides it won't start after being shut off. RE: Truck randomly doesn't want to start, will later. - fixkick - 03-26-2019 (03-26-2019, 06:33 AM)toolman21 Wrote: Plenty of spark on all 4 plug wires, checked with screwdriver arced off metal on engine. the engine will not START NOW, and spark tests good if the engine run now, spark need not be checked,.... obvious but must be asked. engine dead. spark tests good then you lost fueling take off the big air horn pipe, its just a pipe, there is no MAF sensor on this engine (until 1992 , first one in usa 16v) look at it inject, with 2 persons, one looks and other cranks , use mirror so if it back fires, no burned eyebrows. or crank and use camera to photo it injection even make a movie, then watch the movie, safe in bed. the tests are so easy on this engine, spark then fuel. if spark dies, the ECU sees spark die, then cuts fuel so car does not do kinda like " crash an burn thing as seen on TV." (by law) if cmp dies, same thing no spark, and logic above, no fuel. if spark is ok, fueling must happen. does it"? RE: Truck randomly doesn't want to start, will later. - fixkick - 03-26-2019 the injector is so easy to see on this car, do so. and we can work the failure to TRUE cause. the 3 second fuel thing on this car does not exist above 10 Fdeg. if outdoor air temps are above 10Fdegr. then there is NO 3 second prime pulse nor sound of pump , for 3 seconds key on. a 91, would make sound key one, ever time,from the pump. not this car, only cranking and running the FUEL pump runs.... so in every case of 89 the injector needs to be looked at eye balls. no pump sounds can be heard over any starter motor grinding away. RE: Truck randomly doesn't want to start, will later. - fixkick - 03-26-2019 do not be tempted by the dark side. hotwiring any fuel pump relay on this car, or you will blow the ECU to hell, and $400 bill. do not. unless you remove the pink wire at the left rear tail light first. then (umpluged) and hot wire the pump side ONLY. if no injection see here next, g402 rusty? pump ground. http://www.fixkick.com/INJECTORS/PUMP/Pump-Ground1.jpg then look here, below G402 the big connector. ( the pink wire. is pump power if the connector is rusty, ooops. (up side is ECU side, down side is pump) http://www.fixkick.com/INJECTORS/PUMP/Tl2w.jpg http://www.fixkick.com/INJECTORS/PUMP/Tl2w.jpg RE: Truck randomly doesn't want to start, will later. - fixkick - 03-26-2019 to test voltage at the pump wire, you must crank the engine or volts sits at 0vdc. if you crank the voltage will be near battery voltage 10v to 11 volts is par, at 8v the starter chatters like mad. this left rear tail lamp connections love to rust. water gets up there and well rust happens. and under car 2 more pink connectors rust. pink = pump. RE: Truck randomly doesn't want to start, will later. - fixkick - 03-26-2019 are you in the RUST Belt (wiki that phrase) if yes, it rusts 10x faster. locations matter. down here, no rust, at all . what old cars and corrosion, many grounds on the car fail, even head lamps go dim, and more. also the main fuse box on RF fender strut loves to rust. (not down here but Up north, where they salt the roads.) RE: Truck randomly doesn't want to start, will later. - toolman21 - 03-26-2019 Not in rust belt. Injector is pumping gas as expected. There is spark as expected. Would the crank sensor if bad kill the spark, or would spark be there as normal on this particular (89 sidekick) truck? RE: Truck randomly doesn't want to start, will later. - fixkick - 03-27-2019 there is no crank sensor on any 89 ever made. (usa) the spark is all created inside the distributor (and 1 outside coil) the ECU does not make make spark and there is no true CMP cam sensor here at all, only one VR sensor inside the distributor. the crank sensor stated year 1996 up the CMP cam sensor started 1991 up (all comments USA cars) CMP is HALL sensor, that mostly never fails but the 89/90 VR sensors love to fail. VR is variable reluctance sensor, and has gap setting in the manual and on my 89 spark page. fixkick.com even the factory pages on that.. all there. finding intermittent problems on any old car takes, skilled and hard work, can I assume [/b]the below means engine will not start but at that TIME (moments of testing), the below was seen?(proven)? Not in rust belt. (VERY GOOD) Injector is pumping gas as expected. There is spark as expected. so if fooling, are the spark plugs bad, and jet black tipped, Would the crank sensor if bad kill the spark, or would spark be there as normal on this particular (89 sidekick) truck? there is no such thing, on this car., period. nor will any 96 to 98 sidekick Crank sensor kill spark like seen on all Toyota's ok? so forget CKP sensors, there are none here. this cars ECU only does Fueling, the ECU does not create spark on this CAR, nor does it advance timing on this car ever. The Distributor does make all spark all by itself, even on a bench spun dizzy, by hand, and connected to the coil. I can make spark ( a fact) the ECU does in fact Monitor spark ,(and input only to the ECU ) called the tachmeter wire, this brown wire if goes dead the ECU cuts all fueling to prevent a horrible fire, as the engine floods like mad. ever try new spark wires and new spark plugs gapped to 0.028" and never use the out of box gap EVER, OOTB out of the box its 0.045" done by mindless computers, in factories (machines) . using simple and cheap, J plugs from NGK? spec spark plugs. one odd things about engine,s and failure to start, (cranks fast at 300rpm) there are these things. 1: is the crank bolt 17mm hex torqued to 94ft/lbs , per the TSB. ? 2: are you running the cam belt from 100,000 miles an wondering why the timing of same changes every day or week or attempt? 3: ever do the full 60k mile tuneup (aka. full 60k service points) 4: if engine has spark and fuel, ever look at spark plug tips first,( this is called basics in engine diagnosis) 5: if the engine still has spark and fuel, ever do a compression test at WOT? this too is basics, 101 engine diagnosis. if found at 50PSI x 4 not 150 that means the belt slipped. step 2 above. and last, #1 above, the crank cog on this car loves to strip out the key on end of crankshaft,l due to nobody reads TSB's warnings, I would now guess, 2 things, cam timing changes like made. or the distributor has intermittant spark, but the testing is tricky, if I say fuel and the fuel is good, not smelling like old boat fuel, i then check spark quickly and if that is ok, I then do WOT cranking to clear all flooding. if that fails, I look at spark plug tips , i bet black and soaking wet with fuel yes, I then check compression , WOT, must be near or over 1/2 throttle to get air into the engine and let the compression gauge peak the needle. if compression not at spec or 1/3 normal is possible the cam is NO LONGER TIMED. I have no idea the history of this car nor service done in last 60,000 miles (this magic number repeats) 120, 180k etc. is the belt new? is the crank cog at 94fl/lbs, this 94 rule is day one buy car check, never skip this check or wreck a good crankshaft you will. |
