OIL LEAK - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: OIL LEAK (/thread-oil-leak) |
OIL LEAK - Jerry - 01-07-2019 96 geo tracker 1.6.have developed oil leak.cannot find source. oil drips off cat. and it smokes off the converter.i can see no leak? RE: OIL LEAK - fixkick - 01-07-2019 welcome and cheers, happy new year,. im in south america now. on vacation hot here on the beach. 3ps, 4sp, or 5speed stick' 4wd"or 2wd is the oil red? ATF (dexron 3 up) engine oil , sniff test smells like end of engine dip stick? the 2 top causes of engine oil leaks are, the 3 distributor rear seals all love to go hard and crack and leak , loves to, never seen on this old not leak. #2 valve cover gasket and engine tilts rear so it leaks there first. RE: OIL LEAK - Jerry - 01-07-2019 It's a automatic 4 wd. Will check out your suggestions. Thank you. RE: OIL LEAK - fixkick - 01-10-2019 ohhhhh those love to leak ATF try to put clean towel under the leak spot if red oil, its trans. (assumes dexron 3 up) easy now/ a paper towel and say 4 pebbles or spare bolts to hold it down from wind in the night. RE: OIL LEAK - fixkick - 01-10-2019 engines is distrib like or the base housing,then valve cover gasket, never seen on not leaking, most owner just say gee my car likes to mark things,like my male dog does. |
