1989 sidekick Map Sensor - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1989 sidekick Map Sensor (/thread-1989-sidekick-map-sensor) |
1989 sidekick Map Sensor - charlo - 09-05-2018 Hi...could someone tell me the difference between the Map Sensor 18590-61A00 and 18590-80C00. Thanks. RE: 1989 sidekick Map Sensor - fixkick - 09-05-2018 in the usa ? the 80c only works on 89/90 ECU the 61a only works on 91 and newer ECU, usa. the map matches the ECU, for sure. easy no>? RE: 1989 sidekick Map Sensor - charlo - 09-05-2018 Thanks for your quick response.Very helpfull. RE: 1989 sidekick Map Sensor - fixkick - 09-06-2018 (09-05-2018, 10:14 AM)charlo Wrote: Thanks for your quick response.Very helpfull. you are welcome i have done this, i characterized the 61A, here, but ive never tried any 89 MAP. the 89 has different TB and injector too, lots if things are different on that car. 91 to 95 cars 8valve a mostly the same, (not EGR) http://www.fixkick.com/sensors/my-map.html RE: 1989 sidekick Map Sensor - fixkick - 12-08-2023 thanks I did this in 2006 with too much time on my hands, most is not fully edited, just in journal form. I really liked the car, so documented the top failures. on many that I restored in my 4 bay shop. did Sidekicks and motorcycles then. a used and dead sidekick then was like $300 to $500, but not now, prices for used cars is crazy now. NUTS ! endless scalping now. I have 95 wrangler now , restoring it. its running like new just needs minor stuff done. Have 2 newer jeeps too. https://fixkick.com/
