Rebuilt motor now putting it back in and have questions - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Rebuilt motor now putting it back in and have questions (/thread-rebuilt-motor-now-putting-it-back-in-and-have-questions) |
Rebuilt motor now putting it back in and have questions - droptop351 - 08-22-2018 First question I have is what is this wire and where does it go? Its located on the passenger side by the evap canister and comes out of a harness on the fender. Attachment 774/775 in 775 I believe it goes into that yellowish clear harness there. It is a white or yellow with blue stripe and what appears to be a purple/brown dot https://photos.app.goo.gl/535AvsrMfyHdJS1u8 https://photos.app.goo.gl/nNCCkx51oc4JKuJo9 Also does anyone have a diagram showing the routing of the clutch cable? I know theres a clamp on the drivers fender but how it goes from there to the passenger side im not 100% sure. Im sure I'll have more questions in near future ![]() Edit because im silly and didnt post the obvious: 1995 geo tracker 16v 1.6l, manual, 4 wd, hardtop, 2 door, does have ac. RE: Rebuilt motor now putting it back in and have questions - fixkick - 08-22-2018 WHAT CAR? year, engine 8v or 16valves , trans, 2wd/4wd, 4 doors or 2, all wiring varies by those factors. does it have AC? yellow- with blue stripe it seems. the car will have lots of unused wire/conn. for option not opted day 1, for sure. yellow blue is AC engine overheat sensor, if no AC its not connected. as seen here http://www.fixkick.com/air-conditioning.html (08-22-2018, 11:41 AM)droptop351 Wrote: First question I have is what is this wire and where does it go? RE: Rebuilt motor now putting it back in and have questions - fixkick - 08-22-2018 IIRC clutch cable goes forward, then down, then make U turn, under rad bottom tank , clip there, and back to the mount for frame holder for cable then insided cable to bell lever. 10 years ago, it's all I remember. there were other clips too on left side (driver) also, new strut left top. RE: Rebuilt motor now putting it back in and have questions - droptop351 - 08-22-2018 Thanks! I edited the original post to include the information. Ive got it plugged in just above the green connector thats near the thermostat I assume that to be the correct location. RE: Rebuilt motor now putting it back in and have questions - fixkick - 08-22-2018 : 1995 geo tracker 16v 1.6l, 6sp manual, 4 wd, hardtop, 2 door, does have a/c. ok, yes 2door less connectors, no rear wiper no rear washer wires dangling. and more. the AC wiring is all on an addon harness I think, with 2 relays there, for compressor and fan up front there are 3 water temp sensors on this car. 1: 2 pin ECT, for ECU. water temp to run the EFI correctly 2: the 1 pin way front is gage water temp. 3: and the optional 1pin water temp, switch, it is only switch that tells the AC AMP to turn off AC if engine overheats,. rear port on manifold. R > F (3,2,1, a/c,ect,gage ) see on my parts finder page 16v 92-95 http://fixkick.com/sensors/thermostat/96-stat-mine1w.jpg |
