95 Tracker master cylinder diameter ? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 95 Tracker master cylinder diameter ? (/thread-95-tracker-master-cylinder-diameter) |
95 Tracker master cylinder diameter ? - luigi daniel - 08-11-2018 Any idea, the brake master cylinder inside diameter for a ‘95 Tracker, 1.6l 16valves 2door hardtop auto transmission ? Maker Aisin. I need this info to source the right set of seals. Seals only, without piston. Alternative, Suzuki part no. for the seals set ? RE: 95 Tracker master cylinder diameter ? - fixkick - 08-11-2018 id look at rockauto.com never seen anyone ever sell seals , less a piston, after the pistons love to corrode. 7/8" inches cardone says and $22 for the whole thing, rebuilt less , Reservoir,, if you bought seals, only today , you'd risk getting china knockoffs, and on brakes wow.... , check out Raybestos, i use them all the time. and are top quality. why just seals, trying get racing DOT5 fluid to now kill seals? https://www.rockauto.com/en/catalog/geo,1995,tracker,1.6l+l4,1142266,brake+&+wheel+hub,master+cylinder,1836 (08-11-2018, 04:19 AM)luigi daniel Wrote: Any idea, the brake master cylinder inside diameter for a ‘95 Tracker, 1.6l 16valves 2door hardtop auto transmission ? Maker Aisin. RE: 95 Tracker master cylinder diameter ? - luigi daniel - 08-11-2018 Thank you for reply and advices ! Here in Europe we have Autofren Seinsa (seinsa.es) which makes seals only kits as follows : D1788 and D1458 for 22.22mm cylinders and D1277 for 20.6mm cylinders. RE: 95 Tracker master cylinder diameter ? - luigi daniel - 08-11-2018 just for info : Suzuki p.n. to repair 20.6mm master cylinder : 5110060810 Piston set 22.22mm. 5110060850 RE: 95 Tracker master cylinder diameter ? - fixkick - 08-12-2018 sorry, we never been to Europe. $99 for first number $143 for second that $20 Cardone rebuild looks great. and is top company here, not jokers. like seen from ebay. or raybestos (top brand ) https://www.amazon.com/Raybestos-MC39960-Professional-Master-Cylinder/dp/B000C71M44 |
