Adding factory cruise - 1996 tracker 2dr 4x4 (donor 1998 2dr 4x4) - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Adding factory cruise - 1996 tracker 2dr 4x4 (donor 1998 2dr 4x4) (/thread-adding-factory-cruise-1996-tracker-2dr-4x4-donor-1998-2dr-4x4) |
Adding factory cruise - 1996 tracker 2dr 4x4 (donor 1998 2dr 4x4) - renaissanceman - 07-26-2018 Has anyone ever done this? I have someone who is going to pull all the cruise bits from the donor for me. What all is involved? RE: Adding factory cruise - 1996 tracker 2dr 4x4 (donor 1998 2dr 4x4) - canadaescortspage - 11-28-2022 Have a '98 Tracker 4x4 2 door soft top, 190,000 miles. Head gasket leaked, won't run....mechanic says at least one cylinder (#3) needs work. He wants $1400 labor to take engine apart to diagnose, rebuild, etc, plus parts and machine shop charges, but we don't know how many cylinders are damaged, cracks in heads, etc. With 190,000 miles should I: A) have him take it apart and rebuild it or B) buy a used engine with warrantee or a rebuilt engine with warrantee or C) junk it? In the last year I put on a set of tires, new soft top and new clutch. A/C compressor is cooked. toronto vip escorts RE: Adding factory cruise - 1996 tracker 2dr 4x4 (donor 1998 2dr 4x4) - fixkick - 12-14-2022 (07-26-2018, 08:35 AM)renaissanceman Wrote: Has anyone ever done this? I have someone who is going to pull all the cruise bits from the donor for me. I think the engine lacks the power to use cruise. or will be a pain to use, in and out, failures yes was and options. with its own motor to run the the throttle. , drove only one and was not happy with it at all. V6 works vastly better, |
