vsv solonoid - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: vsv solonoid (/thread-vsv-solonoid) |
vsv solonoid - Seberth - 03-28-2018 Broke the vacuume hose nipple off my 96 16v tracker vsv (front side,cannister to plenum) anybody know where to find replacement other than salvage yard? thanks once again, I'm an idiot RE: vsv solonoid - fixkick - 03-28-2018 suzuki 2 door or 4 door.? car has 4 VSV, 2 for egr, 2 for evap G16B engine USA. spec cars, have 2 systems , they sell them, wont be at Autozoned, sorry. do you need a real part number. so the 96 evaL , VSV P/N I will go fetch it now and post it. the one next to the CANISTER, and has vent to AIR tube, (goes no where) that one is 18117-58b30 (named evap purge) fits both door counts but not EGR parts. paste this in the search box. $127 https://www.suzukicarparts.com/parts/1995/Suzuki/Sidekick/JLX/index.cfm?siteid=214820 or is it the other VSV evap , sitting next to the EGR VSV (pair)??? best I can do , lacking photos or exact locations... RE: vsv solonoid - Seberth - 03-29-2018 (03-28-2018, 08:56 AM)fixkick Wrote: suzukiThanks for info, Its the evap purge btw, 2 door w\removable hard top RE: vsv solonoid - fixkick - 03-29-2018 that is the right part, number, for the vsv that is most close to canister, and purge side,. bottom right on hood sticker seen here #50 = 18117-58b30
RE: vsv solonoid - fixkick - 03-29-2018 in 1996, they did use 2 systems for this page. and with #50 and with out. (96-96 years)what i call GEN3. sub classes GEN3a and gen3b, smog controls, are a pain. with calif and federal versions. with I call version 2. above with out is seen here. version 1. http://fixkick.com/sensors/96-16L-plumb1w.jpg RE: vsv solonoid - fixkick - 03-29-2018 part ID 21, is EVAP but has different valve, and p/n. RE: vsv solonoid - Seberth - 04-04-2018 (03-29-2018, 09:54 PM)fixkick Wrote: that is the right part, number, for the vsv that is most close to canister, and purge side,. Can you get me part # for #21? received 18117-58B30 but wrong part thanks need one that connects to evap canister thanks RE: vsv solonoid - Seberth - 04-04-2018 (04-04-2018, 01:13 AM)Seberth Wrote:(03-29-2018, 09:54 PM)fixkick Wrote: that is the right part, number, for the vsv that is most close to canister, and purge side,. My bad, Its # 21 on left side of engine at front for evap connected with short vac line to plenum sorry RE: vsv solonoid - fixkick - 04-04-2018 you didnt tell me which VSV? sorry... i tried to tell you there were 2 VSV for evap...so sorry 1996 suzuki or trackers, some CALIFORNIA cars are different, as are CANADA market cars, regardless of factory made. yes 21 is not 50 and 21 is same prefix 18117-58B10 (egr is different too) this vsv site next to the EGR vsv as pair on a bracket. RE: vsv solonoid - fixkick - 04-04-2018 on some cars, Fed or CALIF. part 50 is not there. 1989 to 1996, lots of parts very different (cal /fed) and the ECU must match them. |
