96 tracker o2 sensor - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 96 tracker o2 sensor (/thread-96-tracker-o2-sensor) |
96 tracker o2 sensor - Seberth - 03-05-2018 what's the easiest way to get to the downstream o2 sensor plug? I assume its in the center console somewhere. RE: 96 tracker o2 sensor - fixkick - 03-05-2018 02 rear, cable goes up, and through hole just above,, under driver seat and under carpet, what you mean plug, Grommet? RE: 96 tracker o2 sensor - '97Sport - 03-07-2018 Yeah, it's under the drivers seat. Just remove the grommet from underneath & the connector is a couple inches up the wire. RE: 96 tracker o2 sensor - fixkick - 03-07-2018 sorry, i did not know you were asking how to unplug the O2, sure, under the see, if you follow the wire, you will land to the connector. as you can see ,dry , rust free connections are best. and under seat, too bad the ones behind the left rear tail light cant keep dry, |
