Crankshaft Pulley Compatibility - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Crankshaft Pulley Compatibility (/thread-crankshaft-pulley-compatibility) |
Crankshaft Pulley Compatibility - junkrier - 01-20-2018 Vehicle: 1995 Geo Tracker Vin 6 16V, Manual trans LSi 4x4 hardtop 2 door w AC and PS Part: Crank pulley, dual pulley flat belts (4 rib?) I am doing a timing belt, water pump, radiator, all hoses, tstat job, the timing cover has grooves worn through it at the crank pulley. I bought a new cover. So, the issue is crank pulley. I think the pulley needs replaced. I found a very good deal on new suzuki esteem 16v 1.6l crankshaft pulley. It looks the same from pictures. Question: Is the crankshaft (dual) pulley from a suzuki esteem 1.6l 16v (1995-2001) compatible with a 1995 tracker vin 6 16v? I have heard conflicting answers, however I consider fixkick the absolute authority on all things tracker/sidekick. Thanks for any help you can provide. RE: Crankshaft Pulley Compatibility - Perry - 01-21-2018 Part numbers match, but I’m no expert. Just waiting around bored for the real guru to show up lol. RE: Crankshaft Pulley Compatibility - fixkick - 01-21-2018 I'M ON A CRUISE, NOW, NO SUZUKI BOOKS, SORRY! THANks perry, P/n match is a match. the car was sold with with no PS and no AC. or both missing or both present, so keep that in mind. why is the pulley bad, they never fail. unless rusted through. bent? accessory pulley is name. photo photo of pulley damage./ (all we have now is its an. ISSUE) good luck !!!! |
