A/C amp issues - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: A/C amp issues (/thread-a-c-amp-issues) |
A/C amp issues - motaratak - 07-26-2017 I have a 1992 Suzuki Sidekick 4dr auto 16v, turbo. I cant seem to get the A/C compressor to engage, it used to work. Did an engine change prior to the turbo, new head and block, hasn't worked since. I back probed the A/C amp and I'm getting 12V coming OUT of the amp at the yellow/blue and 12V going IN yellow/black wire. Is there something in between the engine over heat A/C switch and the a/c amp? RE: A/C amp issues - fixkick - 07-26-2017 as seem here 95 , schematic. http://www.fixkick.com/air-conditioning.html yell/blue is overheat switch engine , 0v is good not ever 12vdc, so if the engine is not stock the switch is missing, so ground this wire. besides fuses, relays and wires.bad. hi-low switch. the pink wire pulls in the compressor relay/ RE: A/C amp issues - motaratak - 07-27-2017 I understand it is ths overheat switch but why is the amp send a 12v signal out on the yellow/blue wire? Its a 16v 1.6 with all of the sensors and switches inplace, its all still there. RE: A/C amp issues - motaratak - 07-27-2017 Found the problem. Yellow/blue wire does not have continuity from the switch to the A/C amp. RE: A/C amp issues - motaratak - 07-27-2017 It was the connector at the switch, fully functional now RE: A/C amp issues - fixkick - 08-01-2017 oops that would do it. easy fix. no make the amp happy and the hi/low happy and clutch pulls in, glad to hear running !!!! |
