removing torque converter Bolts 1995 Sidekick - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: removing torque converter Bolts 1995 Sidekick (/thread-removing-torque-converter-bolts-1995-sidekick) |
removing torque converter Bolts 1995 Sidekick - lstill - 04-22-2017 Hey guys, pulling the motor on my 1995 Sidekick to rebuild. Got every thing ready yesterday to remove except the three torque converter bolts. I can see that the way there inset and hard to reach that there must be a good way to do it. If anyone has removed a 1.6 8 valve sidekick/Tracker motor please could use some advice here.....Thanks.......Larry RE: removing torque converter Bolts 1995 Sidekick - fixkick - 04-23-2017 metric spanner ? or off set box end spanner? what tools fail, ? the pulley can be jogged by hand, with sparks (plugs) out. or with 17mm deep all on crank pulley center bolt. RE: removing torque converter Bolts 1995 Sidekick - john110 - 06-27-2017 (04-22-2017, 07:22 PM)lstill Wrote: Hey guys, pulling the motor on my 1995 Sidekick to rebuild. Got every thing ready yesterday to remove except the three torque converter bolts. I can see that the way there inset and hard to reach that there must be a good way to do it. If anyone has removed a 1.6 8 valve sidekick/Tracker motor please could use some advice here.....Thanks.......Larry Here's what I built thé first time I had to remove thé engine... Back then, I had thé same problem with those 3 bolts... Thé space is kind if tight. It cost me about $10, and I have no problem anymore to remove those. I just did it again 3 days ago and it took me 15 min !! RE: removing torque converter Bolts 1995 Sidekick - john110 - 06-27-2017 Just to complete my post... I used an piece of metal (20" x 1" x 1/4") drill a hole close to the end to insert a socket #14 x 1.5" and welded the socket in it..... the socket is exceeding behind the metal bar by 1/8" but I didn't have to grind it..... The socket has 1 1/8" in front of the metal bar, and its exactly the good distance to make it easy to remove the 3 converter bolts..... the first time I had to remove those 3 bolts, I had some big problems doing it...... so I made this simple tools and it made it 100 times easier to do the job....!! that way you won't strip any of those bolt.....it cost me about $10 to do it.... I removed those bolts on my Tracker just fewdays ago, it's now so easy to do it...... |
