92 vss code 24 - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 92 vss code 24 (/thread-92-vss-code-24) |
92 vss code 24 - GFO4501 - 03-31-2017 Hello group, I am a new member and owner of a 92 tracker, 8v, 5 speed manual, 4x4. It has had a rough life before I bought it and I have made several repairs and improvements. I currently have a code 24 and have hit a snag on repairing it. I must say I am very impressed with the fixkick website and have learned more from it than any other source so far, including the factory service manual I purchased off e-bay. I have used the website as a guide to pull the speedometer and troubleshoot. Here's the kicker, it don't have a reed switch that I can find. I suspected trouble when I noticed there were no v1 and v2 terminal screws on the back. I shined a light in the holes and there was nothing for screws to thread into. After taking the face out and exposing the guts, I can't find the switch or any signs of solder. The magnetic cup is there on the needle and intact. As a matter of fact, everything else looks relatively clean and in good shape. The speedometer does make noise and the needle bounces at certain speeds, though. Any ideas? The website has a picture of a speedometer that appears to be identical to mine except it has the the two terminal screws. I would certainly appreciate any advice on this. Thanks, Greg RE: 92 vss code 24 - fixkick - 03-31-2017 welcome ! DTC 24 VSS DEAD. REDUX 1 (for carbon dating)"true identification and true year and true market" cluster , someone messed with yours. for sure. !!! all post 1989 clusters G16a/b or have a VSS, (in usa, the very first (89year) did not unless cruise option ordered) no carb G16 has VSS. no out of usa cars with other odd setups, (vaST) HAVE IT. but all with real INJECTION EFI, and with full smog controls have it, (some JDM's do not) {JDM}are for JAPAN only and seen on some south pac. islands..etc and are illegal usa, conus) got this TAG? under hood? http://www.fixkick.com/specs/Body-TAGS/images/92federalsticker.jpg RE: 92 vss code 24 - fixkick - 03-31-2017 92 tracker, 8v, 5 speed manual, 4x4. It , , usa(MPH ) or canada (KPH)?????????? our heads 92/.93 here, usa. MPH heads. http://www.fixkick.com/sensors/speedo/CusterPN-92-93.html http://www.fixkick.com/sensors/speedo/cluster-frack.html here is me retaCTING A REED ASSEMBLY. IT HIDES BEHIND THE PLASTIC REAR PART. SCREWS OUT IT LIFTS UP AND OUT. ![]() all 10 years here. http://www.fixkick.com/sensors/speedo/allyears_pdf/all-speedo16L.pdf RE: 92 vss code 24 - fetcher - 03-31-2017 Did you find the images starting with http://www.fixkick.com/sensors/speedo/Speedo_guts/html/image_1.html ? Then, does that look like what you have? I don't know why you are unable to replace the missing screws, but I bet that if you put up some images of what you have Fix Kick will nail the problem right away. RE: 92 vss code 24 - fetcher - 03-31-2017 Wow, his reply was posted as I was still writing RE: 92 vss code 24 - fetcher - 03-31-2017 Wild speculation, but Is it possible to mount that thing upside down? RE: 92 vss code 24 - fixkick - 03-31-2017 once this meter makes noise ,,its doomed finding a good head can be hard. 25 years later, best is buy them used cheap and mix parts to get one good one. the words, speedometer ,assy, means the whole thing. the words, body assy speedmeter is just the internal meter with odom, and vss. in the official Suzuki pages, above PDF the latter meters , some are shared . MOUNT UPSIDE DOWN many SAMMI (jimny) cars , that engine blew up, and owner put in say 91 sidekick engine G16a /b and all EFI found the speedo dead vss, sure no vss on carbs but discovered the magnet still there and just used hot glue gun to anchor a new (easy to buy) reed switch near the mag. and it works at ANY ANGLE , even upside, down. the mag spins so, there is no way for the brain to know how you did it only that the reed toggles. RE: 92 vss code 24 - fixkick - 03-31-2017 upside down, no. it only fits as the photos show, no variances with molded plastic, like that. it has to fit and work, 2 things, its magnetically coupled, reed. RE: 92 vss code 24 - fetcher - 03-31-2017 The needles twist off, mine did. Then maybe the assembly was replaced with the wrong one? Pictures from GFO4501 would be valuable. RE: 92 vss code 24 - fixkick - 03-31-2017 correct head. ![]() seems rare as hens teeth , today... |
