'96-98' Sidekick Sport replacement rims - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: '96-98' Sidekick Sport replacement rims (/thread-96-98-sidekick-sport-replacement-rims) |
'96-98' Sidekick Sport replacement rims - Bayouzukie - 12-05-2016 Followed your advice and an ASE mechanic has the Zuk purring like a kitten! Now to the next project. Getting a second set of rims to put offroad tires on. The stock rims look great but in searching u-pull it yards, google search, etc I can't seem to find anything. Any suggestions on a rim from a later model that would be inexpensive and easy to find? Thanks! RE: '96-98' Sidekick Sport replacement rims - fixkick - 12-05-2016 RIMS the wheel, rims are a standard size that fits many cars, that have that special,inner hub size, that clears the axle lockers, even some USA pickup trucks fit. you do know you can read any wheel makers, online catalog and say look up one wheel and see all cars that it fits ,right? so fits many cars all tries stores will show you all rims made and what fit. spec: on center hold, there is hole pattern and nut size and type. (steel or mag) then width, (and tire inside diameter) and then offset. only they can tell you which rim matches , the tires, and dont hit the frame, fender-wells or or front tire rods etc. not only that the tire profile also dictates what tire /rim will fit and not cause problems. (clearance, turning or bouncing fully) some tire/rims see to fit then on fast turns, they hit. (takes hard work to get a match up,) why not let a tire pro do all that. a wheel/tire man. (12-05-2016, 05:19 AM)Bayouzukie Wrote: Followed your advice and an ASE mechanic has the Zuk purring like a kitten! |
