1995 tracker automatic overheats - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1995 tracker automatic overheats (/thread-1995-tracker-automatic-overheats) |
1995 tracker automatic overheats - Charlieanddawn - 09-11-2013 My 95 Tracker tintop automatic 16v, new radiator,radiator cap,thermostat, Antifreeze moves well thru radiator,fan locks up when warmed up, no cat. Timed 5 before TDC with jumper in place No bubbles in radiator. Issues are EGR 51 code and torque converter does not seem to lock up. We usually carry a load of 650 lbs. After climbing long hills in Colorado anti freeze spits from expansion tank only upon shut off. Eventually expansion tank is empty, but the radiator only needs a little antifreeze to be topped off. Any Ideas? Could it be heat buildup from the torque converter not locking up or the EGR? Thanks Charlie 95 Tracker Tin top 202,000 miles not rebuilt RE: 1995 tracker automatic overheats - fixkick - 09-12-2013 (09-11-2013, 06:00 AM)Charlieanddawn Wrote: My 95 Tracker tintop automatic 16v, new radiator,radiator cap,thermostat, Id , use my IR gun in 5 min hot, 190f or 180f if stock stat. id point my pyrogun ($15) at the rad tubes , after 20mile drive, or until roasting fully hot. and see the same temp, 1inch down from top of tubes, left to right. then see same temp, bottom of tubes, left to right. i did a theramalgram on mine. http://www.fixkick.com/Cooling-engine/therm-o-gram.html any tube left to right that is reading way different that its partner, is clogged. the most amazing tool ever. no burned hands ever.. about 155 f top row and as low as 125 bottom right lower side runs cooler as it is combined total tube effect at bottom tank. but the tubes should all be the same , in a horizontal plane. id bet: 1; Clogged rad tubes. (that AT NEEDS A 100% GOOD RAD, that AT does pukes tons of heat,) 2; Slipping fan belt , some do so with no sound at all. 3: bad impeller on pump. (some get eaten up by electrolysis, so thin nothings.. or full of holes.) IMO the stock RAD size is plenty big, and for sure has excess capacity, so what is eating up that excess? a clogged tube kills the excess capacity, and in the worst case, slow it will over heat. only 2 ways to fail, macro. 1: engine makes too much heat, I think not. 2: bad cooling. http://www.fixkick.com/overheating.html good luck to you. |
