Gear oil temp sensor mounting - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Gear oil temp sensor mounting (/thread-gear-oil-temp-sensor-mounting) |
Gear oil temp sensor mounting - SrgBog - 07-07-2016 Hi. Any body have an idea how to mount Gear oil temp sensor ? Which adaptor should I use ? Maybe some have any ppicture? Thanks !! RE: Gear oil temp sensor mounting - fixkick - 07-07-2016 well , the oil cooler is in the RAD, see those 2 lines you need to make a T adapter in one of the 2 lines, one is hot ATF other is 180F back from rad. heated by the cooling. see the Rad both cools and heats AFT, what line to use, depends on your purpose. my guess the outbound line, other other goes to oil pan. (cooler) you will have to make up something custom. summit racing has fittings. and such. the line , may be inch spec lines, Ive never measure them. but if are they can be flared for flared fittings, and then use same adaptor to what ever you have, ive not seen it. post a photo of what sensor you bought. (07-07-2016, 06:12 AM)SrgBog Wrote: Hi. |
