replaced about all.runs2sec n dies - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: replaced about all.runs2sec n dies (/thread-replaced-about-all-runs2sec-n-dies) |
replaced about all.runs2sec n dies - [email protected] - 07-27-2013 Hey and hello..1991Suzuki tracker. 2dr. Ht. 1.6 ltr 80horse pressure. Repla ed brain. Fuel relay.fuel regulator. Entire throttle body. Hav plenty of fuel pressure. Turn The key .fires.dies.push excelerator it dies.oh and wen it starts Its just 4 TWO SECONDS AND DEAD. CAN SOME ONE HELP ME ? I MEEN WATS LEFT? I HAVE A 2ndCOMPUTER ON WAY IN THE AM ON SAT. I AM REDY TO TEAR ME HAIR OUT WAT LIL I STILL HAV..........JUST BOUGHT IT ON WED. OLD OWNER SAID SHE WAS DRIVIN AND IT JUST STOPED RUNNIN. HAD IT TOWED HOME. SO REPLACED THROTTLE BODY THINKIN VARNISH..... AND YOU KNO THE REST.. SO DISTRAUGHT IM REDY TO CARBORATE... BUT THE $ I HAVE SPENT ALREDY. OM GOSH THIS WAS SPOZTO BE A FUEL PUMP ISSUE AROUND $200. BUT NOWAY I COULD NOT GET SO BLESSED.. IM MORD FUNNY THAN THIS ON MOST DAYZ THANX FOR LETIN ME VENT!!! PLEZE HELP....... RE: replaced about all.runs2sec n dies - fixkick - 07-29-2013 Welcome D.... any thing can be diagnosed. do not make assumptions, and used parts, do fail or are not good. I'll pretend all parts are bad, it's a 91 and that good practice. Want to diagnose it or guess ? there are only 2 ways, only 1 way works every time. ill ask questions in threes. 1: CEL lamp glowing key on. 2: does it go out , as you crank, 3: do you have a tachometer in the dash?, no car spec, but 4wd has a tachometer 2wd dont. so y/n, tacho. if yes, does it move 1/4 inch as you crank the 1 on the tachometer is 1000 so at 300 crank speed, it moves 3/10s up scale, as you crank , and if it runs on test fuel the tacho must go as high as the crank shaft did during the test fuel, test, if not , that will KILL injection. we will find it , i promise, and it all free. (for now) later if you have failure we will prove that, using meters. etc,. you can in fact rent tools. for near nothing,,, Autos stores, , are you in USA? its others reading, it runs on test fuel then stops.., he emailed me, and we did that. we will do test, from easy and cheap to harder and more expensive and not guess. good luck to you. kick (07-27-2013, 01:31 PM)[email protected] Wrote: Hey and hello..1991Suzuki tracker. 2dr. Ht. 1.6 ltr (4wd or 2wd, 3speed or 5speed box RE: replaced about all.runs2sec n dies - fixkick - 07-30-2013 are you ok,? we want you flying , no matter. we want to see dust .... and flying rocks... ask questions, all questions gladly received. cheers RE: replaced about all.runs2sec n dies - bcbud - 11-03-2013 I have the same problem . Turns over, fires and dies......very frusterating RE: replaced about all.runs2sec n dies - fixkick - 11-03-2013 hello bud. welcome. please post car spec. and we dont need to guess, nor buy 3 ECU.s not ever, we can do some very simple tests, on a TBI car is even easier, 4 injector cars can be much harder, 3 more injectors to messup 5 ways from sunday. first the year, car. there are many generations, and year is #1 there are just 3 test to get on track. 1: compression, if 150 PSI , WOT x4 then the belt did NOT slip or strip. the belt must be changed at 60k or its doom city. (found on road dead).. a $20 tool. 2: no spark (or tacho dead) keep in mind, the ECU can not see real spark (30,000 volts) it only sees the tacho signal if dead, the ECU cuts fuel all time or after 3 seconds. the test spark plug is near free. check spark at all 5 places, up to 1995 or 4 , starting in 1996. 3: bad fueling. (too much , none or too little) spark plug tips, wet/dry( injector squirting or not?) if TBI car, you can watch live injections. with EYEBALLS. at any time. please post year car. and displacement if not 1.6L and if 4wd. (or if it has a tachometer in the dash as all 4wd have) |
