Bad ECU 1.6 8v 1990. - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Bad ECU 1.6 8v 1990. (/thread-bad-ecu-1-6-8v-1990) |
RE: Bad ECU 1.6 8v 1990. - fixkick - 11-23-2016 An ECU is a very complex thing vastly so..... name something different please. RE: Bad ECU 1.6 8v 1990. - Lynyrd - 11-23-2016 (11-22-2016, 03:55 PM)Lynyrd Wrote: Is what i can mount this calculator OK for this ecu? Détails are differnrd RE: Bad ECU 1.6 8v 1990. - fixkick - 11-23-2016 I can't speak dutch, (wish yes) but show a photo, after... edit photo. put ARROWS on photo pointing to things you see that are different.? best regards RE: Bad ECU 1.6 8v 1990. - fixkick - 11-23-2016 my guess so far it's ready to go 60a70 matches your 60a70 if in California, they can fail you for the smog codes, even though car passes smog and engine / car operate 100% perfectly. so... what works and what is legal are 2 different things..! here. and other places.... why not try it.? plug it in, keyon with DIAG jumper see code 12 now? flash, pause flash flash, long pause, repeats endless... key on... not even started yet. the only big risk is to that single injector. (valued at $150+) it wont damage the engine, the only risk to engine, is flogging hard a lean engine. But low fuel pressure (common) does this all the time. so.... to plug in any ECU, remove negative battery lug first. to protect and prevent hot swapping any ECU. RE: Bad ECU 1.6 8v 1990. - Lynyrd - 11-23-2016 This ecu ils not mine,is a annonce internet RE: Bad ECU 1.6 8v 1990. - fixkick - 11-23-2016 (11-23-2016, 05:08 AM)Lynyrd Wrote: This ecu ils not mine,is a annonce internet ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhh that be a horse of a different color. Buying ECU is not a fun thing. for sure used. call the seller say , if the ECU is not good, you want money back if they refuse, pass. but then again you never said price,? $10 buy it $100 + ask for DOA returns, means if dead on arrival I get to return it. there are only 3 sources. 1: Suzuki. 2: from ECU major re-builders with warranty. (best) 3: FROM AUCTIONS OR WHATEVER ON THE INTERNET. (called pigs in the poke sack here, or , NO WARRANTY) if bad , now you have 2 bad.... Price is every thing. if low , it's good gamble if high , expect a warranty the rules of life. luck be with you !!!! RE: Bad ECU 1.6 8v 1990. - Lynyrd - 11-23-2016 Thank you very very much!! RE: Bad ECU 1.6 8v 1990. - fixkick - 11-23-2016 graag gedaan RE: Bad ECU 1.6 8v 1990. - Lynyrd - 11-24-2016 No,I m French RE: Bad ECU 1.6 8v 1990. - fixkick - 11-25-2016 Je vous en prie |
