1991 geo tracker doesn't usually start in colder weather. - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1991 geo tracker doesn't usually start in colder weather. (/thread-1991-geo-tracker-doesn-t-usually-start-in-colder-weather) |
RE: 1991 geo tracker doesn't usually start in colder weather. - fixkick - 07-13-2018 are you cheating?,let me explain. where is the meter negative lead, when testing answer connected to the pump wire. minus. not to the car body or it lies to you. the tank is still on the ground. so put the meter on the pump 1 wire connections, 12vdc will be there. (both meter leads on the 2 pump leads at the pump) if the pump is dead, 12vdc will be on the pump. trust the meter, the pumps hot wire goes to the fuel pump relay. the pumps neg lead goes to ground. and both wires can fail. (means wires and every connector on both lines can and do fail.) the motor is a 4 amp load, if there is resistance in the line it will fail. with only 3 ohms resistance in the 2 lines, (power feed) the pump runs at 1/2 speed with 6 ohms 1/3rd speed.(4vdc at pump) as you can see it dont take much bad resistance in the lines to make any pump fail. RE: 1991 geo tracker doesn't usually start in colder weather. - fixkick - 07-13-2018 one guy on the forum put the pump on the rack then forgot to connect the pump wires. at pump. (distractions from his wife or kids will do that) use the meter across the pump, 2 leads there. if 12vdc is across the pump and it is dead, the pump is bad. (rare that on new pumps) but do smack it one time to maybe get the brushes inside to make connections. RE: 1991 geo tracker doesn't usually start in colder weather. - wildfire - 07-14-2018 Thanks fixkick; Not being too multimeter savvy, I guess I misunderstood the meter test, by having the neg ground give me a false reading as to the voltage of my wires and connectors. Once I did the crossover test between the +pos and -neg at the pump wires and then the connector, it showed little to no voltage. So I attached an alligator clip and wire from the neg ground behind the taillight to the neg pump terminal, and voila the pump buzzed once the key was turned on. Since this problem was intermittent over the years, it was a hard one to catch. I haven't tried the full pump test with gasoline yet, but knowing I get it to buzz is satisfying. Glad you were there to assist me. RE: 1991 geo tracker doesn't usually start in colder weather. - fixkick - 07-14-2018 veryt good !! (07-14-2018, 12:54 PM)wildfire Wrote: Thanks fixkick; RE: 1991 geo tracker doesn't usually start in colder weather. - fixkick - 07-14-2018 off my ddm page your car failed this, on the pump wire, any wire can fail this, and connectors are top of the list, every time on any 29year old car. reading 12vdc here, the wire is dead open, and open circuit. (corrosion at terms or wire broken inside the insulation where one can not see) ( the object that fails must be turned on to do the test, in your case 3seconds key or cranked. ![]() http://www.fixkick.com/power-elect/DMM.html |
