Tracker wont start - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Tracker wont start (/thread-tracker-wont-start) |
RE: Tracker wont start - fixkick - 09-12-2015 must be bad master cylinder. (if no air in system) it leaking past its internal seals. (look for leaks everywhere too. an on fire wall above toes. below MC) good to hear the head is better, more power, and MPG great ! RE: Tracker wont start - robbybobby - 09-19-2015 New master cylinder installed, brakes bled, and brakes are squared away and working good! New item: manual transmission fluid. I figured it's never been changed and at 135000 miles I bet it needs it. Drained it and fluid was black and only about 1.5 quarts (guessing because some spilled) ![]() My question is this: what's the easiest way to put new fluid in? I filled the side fill plug but it only took about 2 quarts before it started leaking out. I read that it should take 3.2 quarts to fill. Should I fill until it leaks or am I missing something here? Thanks! RE: Tracker wont start - fixkick - 09-19-2015 4wd. the 4wd 5sp uses the least lube. the 5speed box is closed at the rear, unlike that 2wd. 5speed box. 1.6 quarts,, 4wd, 1.8qt , 2wd. page 200 here. http://ge.tt/2QmBJ2C2/v/0 easy? heat the jug first. i pan of hot water. then but my hoods off. so ... snake the hose more... the pump type, is hard slow long work,, a big pain, gravity is my friend... LOL ! |
