Clutch Release Shaft - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Clutch Release Shaft (/thread-clutch-release-shaft) |
RE: Clutch Release Shaft - sina27 - 01-31-2020 When replacing the clutch, I will also replace the pilot bearing (since a clutch kit includes one) - this pilot bearing is in the flywheel - you mentioned inspecting the tranny pilot shaft bearing and seal - this is a different bearing, correct? I was going to get this clutch kit from RockAuto: https://www.rockauto.com/en/moreinfo.php?pk=2390404&cc=1142288&jsn=12187&jsn=12187 Then this would be the tranny pilot shaft bearing you suggested I replace? https://www.rockauto.com/en/moreinfo.php?pk=221833&cc=1142288&jsn=12156&jsn=12156 And the seal? https://www.rockauto.com/en/moreinfo.php?pk=253570&cc=1142288&jsn=12159&jsn=12159&jsn=12159 Going to order all these soon (in addition to the order from megazip i mnetioned earlier) Cheers RE: Clutch Release Shaft - fixkick - 01-31-2020 (01-31-2020, 05:56 AM)sina27 Wrote: When replacing the clutch, I will also replace the pilot bearing (since a clutch kit includes one) - this pilot bearing is in the flywheel THE FRONT OF the transmission has pilot shaft in to the box, that bearing is checked first, by hand moving the shaft side to side to see if the front top main shaft pilot shaft has play. this is only a tranny check not clutch. RE: Clutch Release Shaft - fixkick - 01-31-2020 nice clutch and seems it come with pilot tip bearing, into fly wheel, 25mm. |
