1992 jlx 4x4 02 sensor - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1992 jlx 4x4 02 sensor (/thread-1992-jlx-4x4-02-sensor) Pages:
RE: 1992 jlx 4x4 02 sensor - fixkick - 11-12-2015 does the cluster CEL lamp glow key on, the go out running? (the 1st check all suzuki 89-95) there is no chocks on EFI, only carbs the EFI systems use fuel tables. for cold the table (inside ECU) is super accurate for fuel evap rates, and runs cold start fuel mixture based on the ECT (coolant temp) sensor readings. That is right it will infact start at -40f in alaska and pure like a kitten. all by the magic in that table. unlike any carb on earth can do. the car starts cold (02 sensors are of line , when cold) 02 is hot running engine usage. called closed loop. the cold 16v engines starts, and races at about 1500rpm cold, if not the IAC is bad. stuck closed. have you inserted the paperclip in the next to battery DLC connector to activate , Diagnostic mode yet. and see the CEL lamp in the cluster flash 12s yet, this is first. always.. covered here http://www.fixkick.com/CEL/CEL.html#OBD1codes v.sig: 92, 16v ,4wd,4door. A/t guess at 4speed does the cluster CEL lamp glow key on, the go out running? (the 1st check all suzuki 89-95) there is no chocks on EFI, only carbs the EFI systems use fuel tables. for cold the table (inside ECU) is super accurate for fuel evap rates, and runs cold start fuel mixture based on the ECT (coolant temp) sensor readings. That is right it will infact start at -40f in alaska and pure like a kitten. all by the magic in that table. unlike any carb on earth can do. the car starts cold (02 sensors are of line , when cold) 02 is hot running engine usage. called closed loop. the cold 16v engines starts, and races at about 1500rpm cold, if not the IAC is bad. stuck closed. have you inserted the paperclip in the next to battery DLC connector to activate , Diagnostic mode yet. and see the CEL lamp in the cluster flash 12s yet, this is first. always.. covered here http://www.fixkick.com/CEL/CEL.html#OBD1codes v.sig: 92, 16v ,4wd,4door. A/t guess at 4speed one way to test the tps switch is to blip the throttle, key on (16v only) and not running and check the voltage there goes 0v , then 5 then 0 each time it returns to zero, if yes, its probably ok. 5v= not idle 0v = idle simple logic input (binary) to the ECU. |
