96 Tracker axle nut wrench - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 96 Tracker axle nut wrench (/thread-96-tracker-axle-nut-wrench) Pages:
RE: 96 Tracker axle nut wrench - fixkick - 05-15-2014 the beauty of all this , is all parts off the shelf. no $100 tool, you might only use once thanks so very much for sharing those very clear photos. and the mil shot, super nice. CHeers ! RE: 96 Tracker axle nut wrench - gorkyb - 05-15-2014 You're welcome. So the tool served its purpose last night. But just to give you guys an idea, as strong as the hardened steel pins I put in are, I still manage to break one with the torque wrench at only 120 psi, I then had to keep going because the locking washer wasn't lining up its holes with the locking nut so I was able to do it with only three pins left on the tool but barely, I was able to torque it up to 150 psi. I finally changed the boots on the CV joints. Once the CV axle is out is actually not hard to do. |
