suzuki intake and TB swap from 91+ to 89-90 car - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: suzuki intake and TB swap from 91+ to 89-90 car (/thread-suzuki-intake-and-tb-swap-from-91-to-89-90-car) Pages:
RE: suzuki intake and TB swap from 91+ to 89-90 car - fixkick - 12-29-2020 (12-29-2020, 07:51 PM)pablo4444 Wrote: Thank you for reply, IN REDso the 89/90 engine now has 91+ head? with 91+ distributor that we know will never work! the hose 32./33 is ported vacuum. and is modeled for EGR flow rates first, then used for vacuum advance. ported vacuum is 0Hg at idle, then as you advance the throttle vacuum rises, to increase EGR flow and retard spark/. if you use the wrong port the vacuum advance is now backwards. (invertered) and vary bad that.
RE: suzuki intake and TB swap from 91+ to 89-90 car - fixkick - 12-29-2020 the 2 engines same distrib housing P/N cams not the same but do not know why, guess, smog reasons. (lift /duration/timed) RE: suzuki intake and TB swap from 91+ to 89-90 car - pablo4444 - 12-29-2020 Thank you, Ok I know it may be confusing to get to the point, but as I wrote before /I know it may be a bit chaotic too many informations at once/ I am keeping all old stuff there exept new intake+TB that means I will NOT BE replacing my old distributor or the camshaft. It will be all the same as it ever was before, so that ECU will be the same old and will be communicating with old stuff as before. old coil old distributor old head old cam old spark plugs all old stuff. I need just to wire it right. 1. Good point on ISC and Ohm issue /yes it may get slower I will adress it when it comes up but thank you really that is something to keep an eye on/ 2. You wrote "the EGR vsv nipple port on the TB, newer, it is ported too, and I think the correct way" thank you also for this information, I can better manage the hoses Best regards RE: suzuki intake and TB swap from 91+ to 89-90 car - fixkick - 12-30-2020 (12-29-2020, 11:36 PM)pablo4444 Wrote: Thank you, Ok I know it may be confusing to get to the point, but as I wrote before /I know it may be a bit chaotic too many informations at once/ I am keeping all old stuff there exept new intake+TB that means I will NOT BE replacing my old distributor or the camshaft. It will be all the same as it ever was before, so that ECU will be the same old and will be communicating with old stuff as before. old coil old distributor old head old cam old spark plugs all old stuff. I need just to wire it right.good luck the hard part here is many persons swapping parts, they have a donor car. (and dynamic endless swapping) not you but is common. or someone else before already did swaps, and chaos endless. me blind. you are very welcome and thanks for sharing your project !! cheers and happy new year to you and yours. RE: suzuki intake and TB swap from 91+ to 89-90 car - pablo4444 - 12-30-2020 Thank you again I also wish you all happy new year, When I have it done Ill let you know how its going on with this project. cheers RE: suzuki intake and TB swap from 91+ to 89-90 car - pablo4444 - 01-03-2021 So today finally after connecting everything /wires, tubes, connectors/ after re-filling of all fluids, I connected the battery and twisted the starting key. After like 15 seconds of cranking I stopped, then I gave her 1 minute break and then again /battery was bit low on power after 2 monts just lying in garage in the cold/ Ok after that minute I twisted the key again after 10 seconds engine caught and /I stepped gently on pedal to keep it on 1200 revs engine purred like kitten./ After I released foot from gas idle dropped to around 500 so I went outside the car waited for about 15 minutes and set the hot idle to 800 with air bleed screw. Tomorrow I will be playing with strobe light to set timing .Fantastic I have now gen 2 intake and TB on my old 89 vitara, thank you again, you helped me a lot. All the best. RE: suzuki intake and TB swap from 91+ to 89-90 car - fixkick - 01-03-2021 what joy to hear that. Bravo and cheers and for sharing any kind of swaps. , swaps are very complex. (can be ) doing generational jumps and mixed parts of vast kinds thanks again for sharing these steps taken. others can benefit, for sure. Have great new year. |
