Poor mileage and running rich - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Poor mileage and running rich (/thread-poor-mileage-and-running-rich) Pages:
RE: Poor mileage and running rich - fixkick - 11-24-2020 (11-24-2020, 05:39 AM)Clint09 Wrote:the other poster here found alien china $17 maf on his, (after proving all else ok) hot idle Injector PW at 3.2mS,, now passing sniffer smog, IM240 test.(11-12-2020, 11:35 PM)fixkick Wrote: as you can see driving and plotting any errant OBD2 car can be really revealing. above software is. Palmer scan software but you have good fuel pressure
OBD2 will show LTFT On a good engine, we can see LTFT (long term fuel trim) about -5% (minus) this is a good sign for fuel trim. A good MAF run a tad tad rich then the 02 trim pulles this to perfect MIX. We can add to inducted air some propane gas to force the 0² sensor to go leaner or richer.(as wanted to test , if closed loop can be hit) Or cause and illegal air leaks to force lean. (a vacuum house pulled) with a good scan tool you can see all sensor live. and trim, and all that. no need for expensive tool just a real scan tool works. the other posted (link above) added air, a vacuum leak and saw o2 wakeup and closed loop and injector PW go from crazy high to 3.2mS (my computer model predicts,2.8MS) close. new maf fixed it, from rockauto (beck,cardone, Delphi has good price. my 96 I once drove around with the EGR defeated dead, (vacuum hose blocked) and ran great, full closed loop idle and 45mph easy cruise. no limphome punishment, did this for friend to prove this out (firmware magic and rules are never known fully unless tested) I have not tried cat free, but that sure will not effect idle and fuel mix, there is no way for ECU to know that, with no code DTC p0421 cat errors) dtc. also the cat monitor is shut down if if The ecu does not like what it sees in O2 Front, sure does, see that many a time, this prevent owners buying new cat, with the test if run (421 cat performance test would lie to you if 02 front is bad) a good thing that. a scan too can watch pending codes too. and is very wise to look at that. for sure the tests that take 2 driving cycles to get DTC stored. that is all i can think of this afternoon good luck to you and happy thanks giving to you and family. |
