Code for Sidekick Sport - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Code for Sidekick Sport (/thread-code-for-sidekick-sport) |
RE: Code for Sidekick Sport - rasmeidirt - 08-27-2019 (08-27-2019, 10:13 PM)rasmeidirt Wrote:The thermostat and its seal have arrived without paying anymore tax!(08-16-2019, 06:37 PM)rasmeidirt Wrote: My sidekick sport is 1996. Tomorrow I will install them. The question after installing the thermostat, do I need to use any sealant to put the thermostat hosing back or not??? RE: Code for Sidekick Sport - rasmeidirt - 08-28-2019 (08-28-2019, 12:01 AM)fixkick Wrote:(08-27-2019, 10:51 PM)rasmeidirt Wrote:(08-27-2019, 10:13 PM)rasmeidirt Wrote:The thermostat and its seal have arrived without paying anymore tax!(08-16-2019, 06:37 PM)rasmeidirt Wrote: My sidekick sport is 1996. That is the Stant thermostat and its rubber seal from rockauto.com. RE: Code for Sidekick Sport - rasmeidirt - 08-28-2019 (08-28-2019, 05:47 PM)rasmeidirt Wrote:(08-28-2019, 12:01 AM)fixkick Wrote:(08-27-2019, 10:51 PM)rasmeidirt Wrote:(08-27-2019, 10:13 PM)rasmeidirt Wrote:The thermostat and its seal have arrived without paying anymore tax!(08-16-2019, 06:37 PM)rasmeidirt Wrote: My sidekick sport is 1996. RE: Code for Sidekick Sport - rasmeidirt - 08-28-2019 (08-28-2019, 05:53 PM)rasmeidirt Wrote:(08-28-2019, 05:47 PM)rasmeidirt Wrote:(08-28-2019, 12:01 AM)fixkick Wrote:(08-27-2019, 10:51 PM)rasmeidirt Wrote: The thermostat and its seal have arrived without paying anymore tax! RE: Code for Sidekick Sport - rasmeidirt - 08-28-2019 (08-28-2019, 10:42 PM)fixkick Wrote:(08-28-2019, 09:05 PM)rasmeidirt Wrote:they all do. (but suzuki real PARTS)(08-28-2019, 05:53 PM)rasmeidirt Wrote:(08-28-2019, 05:47 PM)rasmeidirt Wrote:(08-28-2019, 12:01 AM)fixkick Wrote: on j18 thermostat kits work right, ! not G16 or G13 or others. buy only J18 parts OK> RE: Code for Sidekick Sport - rasmeidirt - 08-31-2019 (08-28-2019, 10:46 PM)rasmeidirt Wrote:After installing the stant thermostat and the seal, I started the car and idle it for the operating temperature. I plugged the scan tool to view the data. Surprisingly, the coolant was 210F?? Why?(08-28-2019, 10:42 PM)fixkick Wrote:(08-28-2019, 09:05 PM)rasmeidirt Wrote:they all do. (but suzuki real PARTS)(08-28-2019, 05:53 PM)rasmeidirt Wrote:(08-28-2019, 05:47 PM)rasmeidirt Wrote: That is the Stant thermostat and its rubber seal from rockauto.com. THE MANUAL ON THIS CAR TELLS YOU THAT IS NORMAL. RTM? J18 IS REVERSE FLOW COOLANT, THIS IS HOW IT WORKS, THERMOSTAT UP FRONT, ECT ON REAR OR HEAD RUNS HOTTER. What I remember is I did install them correctly. The old thermostat is still work. Only the rubber seal was broken. RE: Code for Sidekick Sport - rasmeidirt - 08-31-2019 (08-31-2019, 08:53 PM)rasmeidirt Wrote:(08-28-2019, 10:46 PM)rasmeidirt Wrote: [quote pid='12044' dateline='1566996177'] What I remember is I did install them correctly. The old thermostat is still work. Only the rubber seal was broken. [/quote] Does it has anything to do with the heater core because I did bypassing the heater core??? IF BYPASSED CORRECTLY THAT IS OK, REPLACE CORE WITH HOSE AND OK, IF DONE OTHER WAYS (NO PHOTOS BY YOU) THAT CAN BE WRONG. FOR SURE MESSING UP ANY OTHER HOSES OR COOLANT PIPES. RE: Code for Sidekick Sport - rasmeidirt - 09-01-2019 [quote pid='12060' dateline='1567260673'] YOU NEVER READ THE MANUAL, IT TELLS YOU TEMPS RUN 215F OR A BIT MORE. AGAIN THIS IS A REVERSE FLOW COOLANT SYSTEM UNLIKE THE G16. Themermost is at the front of engine, in the pump housing and sucks cold water. the ECT is on the rear of the head, NOT SAME place as thermostat so the ECT reads hotter than the themostat by DESIGN please end the witch hunts on themostat, now. [/quote] It stamps 180F / 82C Thermostat only on the box. On the thermostat itself, it just reads 50MM. The old thermostat does not say anything either, it must be the aftermarket one as well. Does the rockauto ship me the wrong thermostat?? People say only the OEM has stamp of the specific temperatures on their thermostats, the aftermarket ones do not, is it true??( no human on earth can answer how all thermostat are packaged or stamped, nobody can.) I did install it correctly as you have described with bleed hole up top. Regarding the bypassing the heater core, the hoses 25 and 26 become only one hose, connecting one end and the other end. I CAN NOT SEE WHAT YOU DID LACKING PHOTOS !!!! Is it wrong to do this?? if just hose replacing heater core, it is ok, if you did other bad things there blocking flow SURE THAT IS BAD. People say bypassing the heater core takes away a small heat dissipation area. BS, you can hear people tell lies on the internet all day long. why ask this.? Does it (tell what IT means) contribute to heating up to 210f in the view data of the scan tool?? the scan tool only reads the ECT is that your question? Beside this, the car runs perfectly, smooth and quiet and also accelerate quickly! gee some of these cars in horrible shape, even in limphome mode run great so means ZERO to me.(fixkick) RE: Code for Sidekick Sport - rasmeidirt - 09-02-2019 (09-02-2019, 02:25 AM)fixkick Wrote: if your engine overheats, turn the heater LEVER to hot full and turn off RECIRC LEVER to FRESH AIR, and the engine may be saved, but in your case , MOOT point it is gone. Poor rockauto Stant thermostat!!!!! They put the wrong temperature thermostat in the right box of Sidekick Sport!! Never again. I bring the old thermostat to several local auto wrecking shops. They have many from Toyota and Korean vehicles. I pick up three from the Korean ones that look similar with 82C. I will test them with boiling water to find which one still work! RE: Code for Sidekick Sport - fixkick - 09-02-2019 (09-02-2019, 08:45 PM)rasmeidirt Wrote:BS, bull crap(09-02-2019, 02:25 AM)fixkick Wrote: if your engine overheats, turn the heater LEVER to hot full and turn off RECIRC LEVER to FRESH AIR, and the engine may be saved, but in your case , MOOT point (core)it is gone. those rockauto J18 themostat are good, it is you that is seriously confused. for a fact. your problem is not knowning how reverse flow cooling works and how to diagnose it, your temp readings are now correct. but you fail to know facts. |
