Transfer case noise when in Reverse with brake on - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Transfer case noise when in Reverse with brake on (/thread-transfer-case-noise-when-in-reverse-with-brake-on) Pages:
RE: Transfer case noise when in Reverse with brake on - fixkick - 07-02-2019 the trans adapters from main box to xfr case are the magic that does the fit, 3 main boxes, 3/4/5speed RE: Transfer case noise when in Reverse with brake on - fixkick - 07-02-2019 the trans adapters from main box to xfr case are the magic that does the fit, 3 main boxes, 3/4/5speed RE: Transfer case noise when in Reverse with brake on - hyrific - 08-17-2019 (07-02-2019, 04:01 AM)fixkick Wrote: the trans adapters from main box to xfr case are the magic that does the fit, 3 main boxes, 3/4/5speed Ok so before I purchased a new tranny I got a stethoscope. Turns out it was the catalytic converter right next to the transfer case. So I replaced the cat and all is good. Glad that worked out. If you hear a noise check that your cat hasn't started to disintegrate. Thanks RE: Transfer case noise when in Reverse with brake on - fixkick - 08-17-2019 (08-17-2019, 02:13 PM)hyrific Wrote:(07-02-2019, 04:01 AM)fixkick Wrote: the trans adapters from main box to xfr case are the magic that does the fit, 3 main boxes, 3/4/5speed thanks for sharing/ mine had the same thing, , the CAT itself had this shield with crack in the shield. (that made noise at odd times) noise is a very complex thing on any machine and worse on machines that move. saw one car do the same, and it was a harness clamp on the tranny box, that was undone a bit and the end of the clamp ONLY hit the body, in left turns and only under hard acceleration. took 3 guys on lift to find that, simulating driving and dragging brakes at the same time to simulate loads on the engine. noise can be , very hard to find. |
