Kick down cable remove??? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Kick down cable remove??? (/thread-kick-down-cable-remove) Pages:
RE: Kick down cable remove??? - Rapom - 10-17-2018 Mine is also 4x4 forgot to add that. Also i thought about dropping the rear trand support but realized that you must drop the exhaust too.. i chose to leave it in. My exhaust header back is all brand new. With that in mind i still didnt want to mess with it... couldn't imagine old crusty rusty exhsust trying to remove it.. nope RE: Kick down cable remove??? - fixkick - 10-17-2018 ah yes, 4wd makes it harder, with 2 prop shafts and lower any tranny with those connected. yes, the exhaust is in the way, on some. yes , working on AT boxes, in car, is super hard. 4speed worst. I hope your leaks all stop, and are easy to fix. (cheers to you) and thanks a million for photos' others will love seeing how hard this can be. just a cable. that why, they can plan ahead, that sure is a tight spot to work. Just fixed my jeeps, steering wheel clock spring after the recall guys broke it (DANG). $700 dealer fix, me fix $100 (HOW CAN THEY CHARGE $600 FOR 1 HOURS LABOR/?) They earned stealership moniker. RE: Kick down cable remove??? - GeneinWW - 11-10-2018 (10-17-2018, 03:05 AM)Rapom Wrote: ... couldn't imagine old crusty rusty exhaust trying to remove it.. nopeGood call. I need to replace a header pipe, and I'm putting it off as long as possible. (10-17-2018, 03:29 AM)fixkick Wrote: $700 dealer fix, me fix $100 (HOW CAN THEY CHARGE $600 FOR 1 HOURS LABOR?)This is exactly why I'm starting to do all my own mechanical work. Except maybe exhaust. Takes me a long time to earn that $600. Very grateful to find this helpful site. I'm late to Rapom's party, but want to suggest that the next time you need an oddball o-ring, try an old-fashioned hardware store. There's one near me that even stocks metric o-rings--found a perfect replacement for the dipstick tube. RE: Kick down cable remove??? - Rapom - 11-10-2018 Well i gave it alot of time this time.. im officially calling it! The leak is gone! It was the damn o ring on the kick down cable this entire time! Well now i can finally move on to the next issue. Theres alot that needs mending. RE: Kick down cable remove??? - fixkick - 11-11-2018 great to hear ! those AT boxes can be super hard to seal up, some even have casting flaws. (GM are noted for that) happy trails and cheers ! |
