No brakes after a 360* turn - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: No brakes after a 360* turn (/thread-no-brakes-after-a-360-turn) Pages:
RE: No brakes after a 360* turn - fixkick - 01-11-2019 if car was lifted , some use extended pitman arm , defeating the stops. and then get man killer #2 bump steer ! auzookers.com says You can adjust the steering stops by the steering box, one is on the pitman arm & the other is on the chassis located in the right hand front corner of the vehicle, both are visible from underneath. ![]() as seen here http://auszookers.com/forum/viewtopic.php?f=5&t=35773 |
