Sources for Rebuilt Cylinder Heads G16B - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: Sources for Rebuilt Cylinder Heads G16B (/thread-sources-for-rebuilt-cylinder-heads-g16b) Pages:
RE: Sources for Rebuilt Cylinder Heads G16B - fetcher - 06-11-2017 I think that I am getting somewhere: From: http://www.zukikrawlers.com/showthread.php?t=55121 RE: Sources for Rebuilt Cylinder Heads G16B - fetcher - 06-11-2017 I'm not so sure the indexing is critical. with the 13 teeth I think are on both drive and driven gear, the worst you could possibly be off by is half a tooth or 1/26th of a circle or 13.8 degrees. Looks like there is enough room for adjustment to compensate and put you back near the middle, or I have forgotten all about geometry. RE: Sources for Rebuilt Cylinder Heads G16B - fixkick - 06-11-2017 ON 2ND THOUGHT, IDK RE: Sources for Rebuilt Cylinder Heads G16B - Samoo3 - 10-03-2017 Any updates? RE: Sources for Rebuilt Cylinder Heads G16B - fetcher - 10-08-2017 I thought I explained it. Indexing is not super critical. The distributor gear on the camshaft is press on. You can use the heads with the reluctor if you switch it for the cam driven distributor gear. |
