89 suki sidekick keeps dying-flooded? - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 89 suki sidekick keeps dying-flooded? (/thread-89-suki-sidekick-keeps-dying-flooded) Pages:
RE: 89 suki sidekick keeps dying-flooded? - bruski - 02-04-2017 (01-25-2017, 02:41 AM)fixkick Wrote: flash code, (just like old GM) 12s is good. Gm has the same deal, even back to mid 80s... its not new, not at all, OBD1 is all like this,Yes, can pervent stall if I keep rpms up. Still reading 12---did read 14 once, that.s all. RE: 89 suki sidekick keeps dying-flooded? - fixkick - 02-04-2017 1989 sidekick, first ones built not by cammi but in iwata japan , 8valve engine. map based. floods sometime even hot. wants to stall and flood, .WOT cures stall. this stall is gross misfiring of engine, top cause flooding. in this ase. clean the ISC yeT. 2 wire device, to right of TB, throttle body.? tuned up minus fuel filer (air?) spark plugs set to .028" and never to NGK FACTORY setting .045" it will misfire, lacking proper gaps parked 2 years, fuel was bad I bet, so suspect junk in the injector. that flooding on this TBI engine, is all cylinders. unless 1 cylinder sparks bad, then only IT foods. (spark tips out at flood solves tts mystery,, one is wet others dry. off road only car.. CAT gutted yet.? if yes it kills EGR dead. code 51 for ever. remove egr main vacuum hose and plug it,so it can suck air, (golf Tee'd) if you had driven with the DIAGnostic jumper in place, you see that code causing the CEL lamp coming on before, cause. MaP sensor hoses, clogged, or cracked. make sure vaccum makes it to map. Injector cleaner, Techron can help, it has the good stuff inside, many dont. on the engine, all (not 51) CODES, put ecu into limphome and that is flooding, rich mix, retarded spark, idle controls shut down Limphome is to be avoided, when you see the CEL come on, say limphome, use the diag. jumper to learn what is messing up. It can be something simple old old 89s.... not to many running this old Engine thermostat misssing, or those silly failsafe stats that lock open, preventing engine coolant from reaching 180f temp or more ECT must read 300 ohms hot engine (KEY off,unplug it and ohm it out,with ohm meter, ) 300 = 180f if the engine does not reach 180f the EFI will go nuts on you. next is TB, take off air horn, look in air horn as someone cuts the key to off. that sprayed fuel ends instantly, or injector leaks look for wiring mods (hacks) at those 2 injector wires.... bad news that. and if found flooding never ends those are the first things to check on barn found kick,(parked real long timee) Do know once cat is gutted the EGR must be defected at that hose, above. or bad happens.(egr mod,valve goes nuts0 iD BE ALL OVER flash codes. if the CEL glows, (not NAG mode) then there is CODE,and must be found. now. put the Diag fuse in? keep it in, let it flash for 1 full day ,12,12,12, oops, 14 ECT bad. floods. the ecu can send bunches of errors out. one after the other. 12 is OK code. the CEL CAME ON,, getting the cude would be my #1 know this, the hot Idle rpm is 800, (ac off, accessories off, head lamps off) if not ,then the ISC is failing, in limphome mode,or gross misfiring(heard ,felt and seen rpm drop) The 8v never misfires for vacuum leaks, it just races with full power. EGR stuck open ,misfires super bad. MAP hoses, leaking air, misfires. flooding. hose cracks,or fell off hoses. one car I saw,those hoses were returning to slime they were so old the stock hoses were melting.. new hose time, some have filter in this line that can clog,(did new ,have it) the FPR can fail stick closed and fuel pressure is at 60psi, 2x normal and bam flooding. thats it, RE: 89 suki sidekick keeps dying-flooded? - fixkick - 02-04-2017 seems the CEL coming on driving has ended? |
