RE: 97 Sidekick Sport 1.8L - CUTS OUT AT 1/4 THROTTLE - fixkick - 02-16-2017 one can use a good tool to scan and record all PID data live. drive and record. then come home save the recording to your PC, and then up load them here. we can read that, and tell you what's UP? sure can or to do 1 test on a focused PID the data to collect is (CALLED PID'S) (IN ENGLISH, PARAMETERS LIVE) BEST TIME DO THIS, EASY.WHEN IT MISFIRES. ECT (temp) IAT (temp) MAF (flow rate) 02 (AND plotted by self as seen above. LTFT (fuel trim) RPM LOAD% "ECU Calculted) SPEED. VSS (moving) ------------------------------------------------------------ any DTC ERRORS RUNNING ANY PENDINGS RUNNNG. that is about it,, its not huge list. RE: 97 Sidekick Sport 1.8L - CUTS OUT AT 1/4 THROTTLE - fixkick - 02-16-2017 good to do 3 ways\ hot idle light cruise and under misfire. RE: 97 Sidekick Sport 1.8L - CUTS OUT AT 1/4 THROTTLE - MtTrails - 02-19-2017 (02-13-2017, 09:00 AM)fixkick Wrote: nice tool, one of the very best in the cheap, category, (an Innova is about $160)Is this the sensor I need? [img] free upload[/img]
RE: 97 Sidekick Sport 1.8L - CUTS OUT AT 1/4 THROTTLE - fixkick - 02-19-2017 i cant tell, no maker ,no p/n i cant find there web site, why? there heading there is contradictive , 1.8L is not in any 2006 my guess is the play wild and loose on 3 different engines, its common this disease. ' no tracker ever ever had a j18 , j20 yes, h25.27 yes. G16 yes. more errors, in heading ill do the checks on the seller now.... cant. error 3 fails to say upstream or down stream sensor,they are not the same. where did you find these amateurs? i cant find there store, where did you find this above LINK? on ebay? need parts makers name and p/n there are many good makers all listed on my buy page. my list, do your own catalog lookups and make sure its correct all PNP Bosch 15287 NGK/NTK 15287 Denso DEN234-4031 Delphi (GM)DELPHI ES2003 AC delco 2131354 each company has an e-catalog. eash shows every sensor that fits ever suzuki engine made. there are lots of bad seller out there selling wrong parts endless and cheep. most know that 90% will not spend $15 ship back cost,packing and wasted time, and get to keep your $29 its sad but true buy using real product names, and p/n (buy top BRANDS) and ask seller to promise those are what you get, many photos online are stock photos. useless. dont get me wrong, on ebay bought real Delphi , on sale, and were real. correct name and p/n and asked seller , got the promise. i see ebay sellers (hacks) selling piles of no name sensors and no Partnumbers. showing 1 sensor or $18 and fits 3 engine , lies,, its scam. only on ebay do such scams exist. and gets worse every year. good luck on ebay.... RE: 97 Sidekick Sport 1.8L - CUTS OUT AT 1/4 THROTTLE - fixkick - 02-19-2017 not only that the link is full of malware. sad RE: 97 Sidekick Sport 1.8L - CUTS OUT AT 1/4 THROTTLE - MtTrails - 02-19-2017 OK, got it running great again thanks to all your help guys. Here's what I did. 1. Replaced all 4 COP's 2. I found the adjusting nuts loose on the throttle cable and it was very so tight that it wasn't idling down all the way. I don't know if this had anything to do with it missing, maybe a sensor somewhere on the cable somewhere send bad signal to the computer, I just don't know. But I drove it twice today and it ran like a top again. RE: 97 Sidekick Sport 1.8L - CUTS OUT AT 1/4 THROTTLE - fixkick - 02-20-2017 sure that causes the TPS TO LIE! on all sidekicks /vitara and grands. SO then RPM WAS NOT 800 SPEC>?hot? wish I knew that... IF You fixed any of the 3 cables.. all 3 are slack, see SM on how.(is a large amount of slack, 10mm slack. (7/16" inches) G16, i do no have a J18 book, super rare they are, but, id bet same, due to same thermal reasons. (alaska to death valley, no jam) so do it correct now. all 3. then now, the tps is no longer calibrated! 0.5vdc rules (predicates) the tv must not be blocked with gunk(bottom of tV PLATE)common. the TV cables,all 3, must be slack, never set tight,ever. (hopeless) IF CAR IS AUT0OMATIC? ;THE KICK DOWN CABLE MUST NOT JAM, OR ALL 3 CABLES jam, INCLUDING CRUISE. OR ALL BETS OFF... my guess, is the ECU knew the TPS is out of calibration, so it had to simulate it, and that always causes, running problems..(takes live scans driving to see this) in fact what happened is tps works then fails then works then fails,, due to above, scanning driving would have found this...!!! it was not misfiring. we know now. (spark misfiring was not IT) it was pure TPS related, (microbogs. normally the tps signals enrich mode, if not, it bogs tipped in, then recovers. since i cant drive car and feel that, my guesses will be wrong) that is why I kept saying did the event bad(hickups) ,end if you pump the throttle ,at the event off failure. ONLY. alls well that ends well. PS: ALSO EXPLAINS THE TPS ERRORS AND CALIBRATION STEPS , 1/2 WORKING, BUT no need for $200 + new TPS sensor. good sure wish i could drive it. The TPS failures, are classic. (micro bogs are not misfire,its lean bogging, staving ofr fuel for an instant.) misfire is very violent and can not be recovered, in most cases.... in fact adding load,to and engine with true spark misfire,causes it to get worse due to higher cylinder pressures. the opposite t of dead tps. The ECU goes to limphome with dead tps, or just simulates it, all simulations are poor at best. good lluck RE: 97 Sidekick Sport 1.8L - CUTS OUT AT 1/4 THROTTLE - fixkick - 02-20-2017 what is simulations on race cars, if sensor dies, that is it, dead engine.(dumb custom ECU)generally speaking) on road cars. the PCM has monitors. (OBD ways and means) these monitors are smart, and if any sensor, dies, it is then simulated. and you can drive, not perfect but drive you can,saving a nice $300 tow bill each time. in your case if the TPS dies, the PCM used MAF data for simulated TPS, and then bogs, at ever tip in of the right foot, that is because the MAF is very very slow. The key is using a scan tool and see the TPS fail live ,driving, or its all just guessing... RE: 97 Sidekick Sport 1.8L - CUTS OUT AT 1/4 THROTTLE - fixkick - 02-20-2017 in fact the TPS hides the effect of a slow MAF on all cars. on jeeps, it hides the slow map the engine, must go richer to accelerate, (or bogs) and must do so , in and instant, super fast, in fact as fast as an injector and change duty.fast. the TPS does this act first. (tps is driver demand for power) knowing this makes diagnosis more easy. RE: 97 Sidekick Sport 1.8L - CUTS OUT AT 1/4 THROTTLE - MtTrails - 02-20-2017 (02-20-2017, 01:18 AM)fixkick Wrote: in fact Remember the other cable I told you about that goes down to the transmission I believe? Well, like I stated earlier, it is completely slacked off and does nothing However, it kicks down into passing when I press the throttle, so I don't know what that is for. Mine only has 2 cables on it I think. |
