Replacement Keys 2008 JK (glow box guide words below..... RTM?) ---------------------quote-------------------------------- NOTE: Only keys that are programmed to the vehicle electronics can be used to start and operate the vehicle. Once a Sentry Key is programmed to a vehicle, it cannot be programmed to any other vehicle. (no used keys can be programmed!) At the time of purchase, the original owner is provided with a four-digit Personal Identification Number (PIN). Keep the PIN in a secure location. This number is required for authorized dealer replacement of keys. Duplication of keys may be performed at an authorized dealer or by following the customer key programming procedure. This procedure consists of programming a blank key to the vehicle electronics. A blank key is one that has never been programmed. NOTE: When having the Sentry Key Immobilizer System serviced, bring all vehicle keys with you to an authorized dealer. Customer Key Programming If you have two valid Sentry Keys, you can program new Sentry Keys to the system by performing the following procedure: 1. Cut the (metal) additional Sentry Key Transponder blank(s) to match the ignition switch lock cylinder key code. 2. Insert the first valid key into the ignition switch. Turn the ignition switch to the ON position for at least three seconds, but no longer than 15 seconds. Then, turn the ignition switch to the LOCK position and remove the first key. 3. Insert the second valid key into the ignition switch. Turn the ignition switch to the ON position within 15 seconds. After 10 seconds, a chime will sound. In addition, the Vehicle Security Alarm Indicator Light will begin to flash. Turn the ignition switch to the LOCK position and remove the second key. 4. Insert a blank Sentry Key into the ignition switch. Turn the ignition switch to the ON position within 60 seconds. After 10 seconds, a single chime will sound. In addition, the Vehicle Security Alarm Indicator Light will stop flashing. To indicate that programming is complete, the Vehicle Security Alarm Indicator Light will turn on again for three seconds and then turn off. The new Sentry Key is programmed. The Remote Keyless Entry (RKE) transmitter will also be programmed during this procedure. Repeat this procedure to program up to eight keys. If you do not have a programmed Sentry Key, contact your authorized dealer for details. NOTE: If a programmed key is lost, see your authorized dealer to have all remaining keys erased from the system’s memory. This will prevent the lost key from starting your vehicle. The remaining keys must then be reprogrammed. All vehicle keys must be taken to an authorized dealer at the time of service to be reprogrammed. ----------------------------------------------------- on newer jeeps? DIY progrogramming is not allowed. read the user guide, it says, just that, in a clear statement. My local key shop can and did , in fact , program 3 new keys I bought from KeyFobMall.com
