transfer case seal, check it. this case end is dry. on 4wd |
i did not replace the needles, they were all like new. so... good to go. |
i used this when , the bear puller fails to gain purchace. if with press, it just works, if no press, use this and hit shaft with WOOD only, and soft hammer. snap rings off, in call cases. this one tool, is neeed. |
optional and makes all steps easy. Harbor Fright? |
